Thread: Golf CR 2.0 Tdi EGR Valve - Connector Wiring Schematic - 2009 CBAB
Results 1 to 10 of 19
  1. Golf CR 2.0 Tdi EGR Valve - Connector Wiring Schematic - 2009 CBAB
    Oct 2018
    Standish, Lancs
    Folks
    I'm suffering intermittent limp mode failures, usually on gentle inclines with engine under light load and light acceleration - revving hard up a steep hill does not throw a code.
    Anyway, I'm seeing the usual P0401 - this is a December 2009 CBAB GT TDI 140 with the separate EGR cooler pipe behind the block and the EGR valve under the top cover.
    Having covered 80,000 miles, I stripped the EGR valve - it was cleaner than expected with minimal build-up - it's shiny now.
    The vacuum actuation of the cooler pipe valve appears to function correctly when I apply manual vacuum.
    I need the pin-out of the EGR valve connector, please.
    This will enable me to manually activate the valve and measure the valve position voltage - one further item to eliminate.
    Chopps
  2. Re: Golf CR 2.0 Tdi EGR Valve - Connector Wiring Schematic - 2009 CBAB
    Jun 2016
    Glasgow
    If your going to that trouble just actuate with scan tool and monitor position with live data (or oscilloscope if you want to go to town). If you are powering manually you’ll need a PWM supply.
  3. Re: Golf CR 2.0 Tdi EGR Valve - Connector Wiring Schematic - 2009 CBAB
    Oct 2018
    Standish, Lancs
    Yes, I know this - what I don't have are the connx for the solenoid and position sensor.
    If anyone can help with an answer to my question, it would be much appreciated.
  4. Re: Golf CR 2.0 Tdi EGR Valve - Connector Wiring Schematic - 2009 CBAB
    Jun 2016
    Glasgow
    You don’t need them if you know what you’re doing.
  5. Re: Golf CR 2.0 Tdi EGR Valve - Connector Wiring Schematic - 2009 CBAB
    Oct 2018
    Standish, Lancs
    As vag_tech clearly is not interested in helping, merely stroking his own ego - maybe someone else can point me in the right direction.
  6. Re: Golf CR 2.0 Tdi EGR Valve - Connector Wiring Schematic - 2009 CBAB
    Jun 2016
    Glasgow
    Quote Originally Posted by chopper_harris View Post
    With my ego sufficiently stroked for the day...if you PM your reg, I’ll grab the requested info for you.
    My point earlier was that if you are going to complete testing, of course you’ll need to know what results to expect and how to interpret them or they’ll hold zero diagnostic value...and if you know what to expect, then identification of test points is obvious, given the results.
  7. Re: Golf CR 2.0 Tdi EGR Valve - Connector Wiring Schematic - 2009 CBAB
    Jun 2016
    Glasgow
  8. Re: Golf CR 2.0 Tdi EGR Valve - Connector Wiring Schematic - 2009 CBAB
    134 Post(s)
    2021 Post(s)
    If you remind me on Monday I will post the proper VAG diagram which shows the internal connections
  9. Re: Golf CR 2.0 Tdi EGR Valve - Connector Wiring Schematic - 2009 CBAB
    Oct 2018
    Standish, Lancs
    Many thanks - reminder sent
  10. Re: Golf CR 2.0 Tdi EGR Valve - Connector Wiring Schematic - 2009 CBAB
    134 Post(s)
    2021 Post(s)
    Bit flipping late sending me a reminder for Monday at 7.46pm Friday.....
  1. Please Help Dsg mechatronic connector wiring
    By Sueday in forum Golf MK6 - 2009 - 2013
    Last Post: 04-06-2018, 09:55 PM
  2. Question MK4 Golf 1.4 AXP - Replacing knock sensor wiring and connector?
    By 22trucks in forum Golf MK4 - 1999 - 2004
    Last Post: 26-06-2014, 04:48 PM
  3. egr wiring connector
    By boidy in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 19-05-2014, 07:19 PM
  4. Please Help Identifying Wiring Connector
    By shipoopi in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 02-03-2010, 11:22 AM
