Thread: Squeaky steering column. Whats the cure ?
  1. Squeaky steering column. Whats the cure ?
    Mar 2007
    Hi, I understand that this is quite a common problem, and it is the rubber bush at the base of the steering column. But does anyone know how to cure it, its doing my head in!! Many thanks.
  2. Re: Squeaky steering column. Whats the cure ?
    Mar 2008
    Did you get any joy with this - I am going mad!! - I assume its a case of having the bush changed.
  3. Re: Squeaky steering column. Whats the cure ?
    Dec 2007
    Been there myself, it's just a dry joint, try some wd40 on the joint, you should lose the squeek after a bit
  1. 04 Audi A4 Steering Column Rattles
    By bloke69 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 02-06-2011, 02:58 AM
  2. MK3 Steering Column Help
    By Alun in forum Golf MK3 - 1993 - 1999
    Last Post: 24-04-2007, 06:46 PM
  3. prevention is better than cure Vs if its not broke dont fix it
    By yogise in forum Passat - Archive Topics
    Last Post: 30-03-2007, 11:11 PM
  4. Squeaky Steering on Audi A4
    By Tess in forum Archive posts
    Last Post: 19-03-2007, 03:19 PM
  5. Excess movement in steering column
    By zak in forum Passat - Archive Topics
    Last Post: 12-07-2006, 09:49 AM
