Thread: Suspect broken cables on Polo door
  1. Suspect broken cables on Polo door
    Jul 2007
    Today I have lost the ability to lock/unlock via the central locking on the drivers
    door on my 2001 polo, I can lock all doors from the passenger side so the
    central locking pump is fine
    I am guessing it could be a broken cable/cables that run from the door
    to the main car, because the the electric windows switches only half work
    and the door lock/unlock button has stopped doing anything, this has all
    happened at the same-time by the way
    The reason I think it's the cables is, that when it went for a service last year
    VW noticed that you couldn't open the windows when the drivers door was opened,
    Does anybody have any advice on the possibility of replacing or checking
    the cabling
  2. Re: Suspect broken cables on Polo door
    Jul 2007
    Well that was painless enough
    Pulled back door rubber cable gator to find a cable
    cut in half guess it was a main feed as it was
    a thick gauge wire black and white in colour
    anyway it must of been botched repaired before
    I bought the car as there was a little piece of tape
    on one end, looks like they had just twisted the ends
    together
    So I got my soldering iron out and joined it back together
    then gave it a good layer of PVC tape, hopefully will last a
    while now.
  3. Re: Suspect broken cables on Polo door
    Aug 2007
    If you're going to have a problem, the ones that are easy to sort are the best
  1. Drivers Door Lock - Broken
    By Paulpro in forum Polo - Derby - Lupo - Fox
    Last Post: 17-02-2008, 10:55 AM
  2. 2003 A4 Cab - Broken cable in door/CMM error?
    By grey_matt in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 16-09-2007, 02:23 PM
  3. Where to guide cables?
    By hogiapesda in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 27-08-2007, 10:08 AM
  4. Golf driver's door handle forced (screwdrivered) and broken into
    By Mungler in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 08-06-2007, 08:01 AM
  5. Broken door lock barrel / paddle
    By 27motorhead in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 24-04-2006, 04:41 PM
