Thread: Front anti roll bar bushes replacement on B7
  1. Front anti roll bar bushes replacement on B7
    Feb 2017
    Edinburgh
    I need to replace just the bushes on our B7 rather than the complete front anti roll bar and I'm struggling to find any details on it.
    Has anyone done this? Is it straight forward to do or a nightmare?
    Ive seen videos of it on the B6 which seems a doddle but the bushes on the B7 don't seem anywhere near as easy for access, especially as I don't have a ramp
    Any suggestions?
  2. Re: Front anti roll bar bushes replacement on B7
    131 Post(s)
    1975 Post(s)
    You cannot buy the bushes from VW, I can’t check from home if people like Febi do them but Powerflex Great deals from Audi Seat Skoda VW Volkswagen Parts on Front anti roll bar | eBay Shops do, you need to know its diameter, 22, 23 or 23.6 mm. The nasty bit is they are evil to replace, you have to drop the subframe and release it from the steering rack. You MUST use alignment pins to preserve the consul locations and every single bolt and nut you touch MUST be replaced as they are one time only Torque To Yeild stretch bolts so this complicates things getting all the fasteners ready. Then with the roll bar out, you have to carefully drill out the peened over fold of the upper to lower clamp and when rebuilding it is advisable to tack weld the two back together as otherwise the assembly keeps dropping apart as you struggle to rebuild it which brings forth language that may offend those around you. On yer back with the car on stands, stuff that! Ohh and the ball joint studs tend to snap off which means new ball joints...
  3. Re: Front anti roll bar bushes replacement on B7
    Jan 2016
    Winchester Hants
    29 Post(s)
    I've soiled me pants thinking about that repair....
    2013 B7 Passat BlueMotion Sport Estate 2.0 TDi 177PS (CFGC), 6 speed Manual, Metallic Night Blue, Fontana alloys, Start/Stop, RNS-510 (HW H09, SW 5238 V13 maps, 8316) Nav DAB, ACC, XDS, TPM, Westfalia Tow bar, Rear View camera, Keyless Entry, Easy Open/close Electric Tailgate, Park Assist, Electric Parking Brake, DRL's, Amb light, Zebrano wood, Tinted Glass, mud flaps, 61K. Cheat emission software. Nextbase 402G iN-CAR CAM.
  1. Please Help Front anti roll bar bushes replaced not sure I’m happy with the fit!
    By Strath44 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 18-05-2018, 11:06 PM
  2. Passat b6 front anti roll bar bushes
    By waynetdi130 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 19-02-2016, 10:35 PM
  3. front anti roll bar bushes
    By passat 130 tdi in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-06-2013, 08:40 PM
  4. Question Front anti roll bar bushes
    By ssopho in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 07-12-2011, 10:54 PM
  5. Front Anti Roll bar Bushes - How much??
    By CPD in forum Golf MK4 - 1999 - 2004
    Last Post: 09-04-2008, 06:05 PM
