Thread: 5 fault codes showing, fuel gauge displays empty, 00438 - fuel supply sensor 2 (G169)
  1. 5 fault codes showing, fuel gauge displays empty, 00438 - fuel supply sensor 2 (G169)
    Dec 2018
    Cleator Moor
    My Audi A6 2008 is giving me trouble as the fuel gauge on the instrument cluster says that the tank is constantly empty when it’s half full and it only just popped up after plugging the VCDS Vag Com for the first time to read the fault codes that may be hiding within the system but after a full scan check that car beeped loads and multiple errors came up one after another.
    Can an any one advise why this is happening and what aproperate way I should tackle this issue so I can have a error free. Car that doesn’t beep at me a thousand times when started
  2. Re: 5 fault codes showing, fuel gauge displays empty, 00438 - fuel supply sensor 2 (G169)
    134 Post(s)
    2022 Post(s)
    How old is the battery? Are you getting quiescent voltage errors in the battery monitoring unit memory?
  3. Re: 5 fault codes showing, fuel gauge displays empty, 00438 - fuel supply sensor 2 (G169)
    Dec 2018
    Cleator Moor
    I not 100% sure but I have copied the VCDS read out that list all the errors on the system
    Sunday,23,December,2018,18:56:52:62939
    VCDS -- Windows Based VAG/VAS Emulator
    VCDS Version: Release 12.12.0 (x64)
    Data version: 20130910
    Chassis Type: 4F (4L0)
    Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 37 42 46 47 4F 52 53 56
    61 62 72 77
    VIN: WAUZZZ4F68N105248 Mileage: 197550km/122751miles
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    07-Control Head -- Status: OK 0000
    0E-Media Player 1 -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    37-Navigation -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    4F-Centr. Electr. II -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    56-Radio -- Status: OK 0000
    61-Battery Regul. -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine Labels: Redir Fail!
    Part No SW: 03G 906 016 MF HW: 03G 906 016 MF
    Component: R4 2,0L EDC G200CG 1142
    Revision: --H06--- Serial number:
    Coding: 0000076
    Shop #: WSC 80093 222 69422
    VCID: 73E539471240F386991-8026
    1 Fault Found:
    000833 - Camshaft Position Sensor (G40)
    P0341 - 000 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00110000
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 197556 km
    Time Indication: 0
    Date: 2018.12.23
    Time: 06:27:37
    Freeze Frame:
    RPM: 189 /min
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 10.03 V
    Bin. Bits: 00001000
    Idle Stabilization: 0.0∞KW
    (no units): 32.0
    Readiness: 0 0 1 0 1
    Address 02: Auto Trans Labels: 01J-927-156.lbl
    Part No SW: 4F9 910 155 B HW: 01J 927 156 JG
    Component: V30 01J 2.0l PD RdW 0010
    Revision: --H03--- Serial number: 00000000000015
    Coding: 0000001
    Shop #: WSC 02325 785 00200
    VCID: 2A5BE423850AF24EEA7-807F
    No fault code found.
    Address 03: ABS Brakes Labels: 4F0-910-517.lbl
    Part No SW: 4F0 910 517 AC HW: 4F0 614 517 T
    Component: ESP8 front H01 0070
    Revision: 00000000 Serial number: 00000000000000
    Coding: 0020856
    VCID: 65C1571FAC941D36075-8030
    Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
    Part No SW: 4F0 910 852 HW: 4F0 905 852 B
    Component: FBSAUDIC6 ELV H31 0230
    Coding: 0000147
    Shop #: WSC 02323 785 00200
    VCID: E3C5C90722A0E306691-80B6
    Subsystem 1 - Part No: 4F0 910 131 E
    Component: FBSAUDIC6 EZS H46 0080
    Subsystem 2 - Part No: 4F0 910 220 D
    Component: FBSAUDIC6 IDG H01 0040
    No Faults Found
    or DTCs not supported by controller
    or a communication error occurred
    Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
    Part No SW: 4F1 910 732 D HW: 4E0 035 729
    Component: Interfacebox H43 5570
    Revision: 00000000 Serial number: 350AU087852289
    Coding: 0001002
    Shop #: WSC 02335 785 00200
    VCID: 2541171FEC14DD36C75-8070
    Subsystem 1 - Part No: 4F0 910 609 E
    Component: Bedienteil MMIC6H01 0060
    Subsystem 2 - Serial number: 00000000972937
    Subsystem 3 - Serial number: 0121.01.080000000100011071ˇ
    Subsystem 4 - Serial number: 011071ˇ
    Address 08: Auto HVAC Labels: 4F0-910-043.lbl
    Part No SW: 4F0 910 043 A HW: 4F2 820 043 P
    Component: KLIMABETAETIGUNGH30 0020
    Revision: 00000052 Serial number: 00000000483453
    Coding: 0001300
    VCID: 1C3732FBDF5E1CFE68B-8049
    Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
    Part No SW: 4F0 910 279 K HW: 4F0 907 279
    Component: ILM Fahrer H18 0250
    Revision: 00000000 Serial number: 4F0907279
    Coding: 0001101
    VCID: 3169F34FA8DC81962BD-8064
    Subsystem 1 - Part No: 4F2 910 113 B Labels: 1KX-955-119.CLB
    Component: Wischer AudiC6 H04 0190
    Coding: 00064784
    Shop #: WSC 02335
    Subsystem 2 - Part No: 4E0 910 557 B Labels: 8K0-955-559.CLB
    Component: REGENLICHTSENSORH13 0100
    Coding: 00146221
    Shop #: WSC 02335
    Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
    Part No SW: 4E0 910 110 E HW: 4E0 035 110 A
    Component: MP3-Changer H46 0390
    Revision: 00046002 Serial number: AUZ5ZBH4072846
    Shop #: WSC 00000 000 00000
    VCID: 1A3B34E3D56A62CE7A7-804F
    Address 15: Airbags Labels: 4F0-910-655-8R.lbl
    Part No SW: 4F0 910 655 E HW: 4F0 959 655 B
    Component: 4E AIRBAG AUDI8RH30 0280
    Revision: 09H30000 Serial number: 0037LD0W5VUD
    Coding: 0013381
    VCID: 29591B2F800CF956E3D-807C
    Subsystem 1 - Serial number: 6332CSME32715229Z
    Subsystem 2 - Serial number: 6342CSME37323004R
    Subsystem 3 - Serial number: 6352QSME421C31639
    Subsystem 4 - Serial number: 6362QSME4C2E1B65X
    Subsystem 5 - Serial number: 63734SME4D2C3A3FK
    Subsystem 6 - Serial number: 63834SME50393153V
    Address 16: Steering wheel
    Cannot be reached
    Address 17: Instruments Labels: 4F0-920-xxx-17.clb
    Part No SW: 4F0 920 983 P HW: 4F0 920 983 P
    Component: KOMBIINSTR. 0900
    Revision: 00500000 Serial number: AYR045779
    Coding: 2279881
    Shop #: WSC 00779 210 91873
    VCID: 3979CB6F70AC49D693D-806C
    5 Faults Found:
    00438 - Fuel Supply Sensor 2 (G169)
    010 - Open or Short to Plus
    Freeze Frame:
    Fault Status: 01101010
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 224
    Mileage: 197556 km
    Time Indication: 0
    Date: 2018.12.23
    Time: 06:51:41
    01319 - Control Module for Distance Control (J428)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 224
    Mileage: 197556 km
    Time Indication: 0
    Date: 2018.12.23
    Time: 06:51:41
    01310 - Level Control System Control Module (J197)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 224
    Mileage: 197556 km
    Time Indication: 0
    Date: 2018.12.23
    Time: 06:51:41
    01771 - Control Module for Headlight Range (J431)
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 224
    Mileage: 197556 km
    Time Indication: 0
    Date: 2018.12.23
    Time: 06:51:42
    00003 - Control Module
    005 - No or Incorrect Basic Setting / Adaptation
    Freeze Frame:
    Fault Status: 01100101
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 224
    Mileage: 197556 km
    Time Indication: 0
    Date: 2018.12.23
    Time: 06:51:43
    Address 19: CAN Gateway Labels: 4L0-910-468.lbl
    Part No SW: 4L0 910 468 A HW: 4L0 907 468 B
    Component: J533__Gateway H06 0060
    Revision: 00H06000 Serial number: 1100B081118200
    Coding: E5519E5730320600
    Shop #: WSC 02334 785 00200
    VCID: 2D51EF3FB4E4E5760F5-8078
    Address 37: Navigation Labels: 4E0-910-88x-37.lbl
    Part No SW: 4E0 910 888 P HW: 4E0 919 887 M
    Component: MNS ECE H51 1060
    Revision: 00000000 Serial number: 364AX087752387
    VCID: 3B75D1677A907BC6811-806E
    Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
    Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
    Component: TSG FA H12 0210
    Revision: 00000000 Serial number: Ex0
    Coding: 0003610
    Shop #: WSC 02327 785 00200
    VCID: 2C57E23B8FFEEC7E18B-8079
    Address 46: Central Conv. Labels: 4F0-910-289.lbl
    Part No SW: 4F0 910 289 J HW: 4F0 907 289 J
    Component: Komfortgeraet H26 0210
    Revision: 02100026 Serial number: 01092801330000
    Coding: 0002811
    Subsystem 1 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Subsystem 2 - Part No: 4F0 910 177
    Component: Innenraumueberw.H01 0020
    Address 47: Sound System (J525) Labels: Redir Fail!
    Part No SW: 4F0 910 223 M HW: 4F0 035 223 N
    Component: Amp.-ASK-RD H07 0270
    Revision: S1300000
    Coding: 030001
    Shop #: WSC 02399 823 56573
    VCID: 285F1E2B5B06C05EFC3-807D
    Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
    Part No SW: 4F0 910 280 HW: 4F0 907 280 A
    Component: ILM Beifahrer H12 0100
    Revision: Serial number: 00000000354390
    Coding: 0001104
    VCID: DEB3F8F309C2CEEE46F-808B
    Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
    Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
    Component: TSG BF H12 0210
    Revision: 00000000 Serial number: prA
    Coding: 0003610
    Address 53: Parking Brake Labels: 4F0-910-801.clb
    Part No SW: 4F0 910 801 C HW: 4F0 907 801 A
    Component: EPB CDEC0080 H04 0080
    Revision: --H04---
    Coding: 0000131
    Shop #: WSC 02324 785 00200
    VCID: 204F060BF336381EB43-8075
    Address 56: Radio Labels: 4E0-910-541.lbl
    Part No SW: 4E0 910 541 T HW: 4F0 035 541 L
    Component: TUNER EU/US/RDW H42 0630
    Revision: 00000000 Serial number: 394A.087856509
    Coding: 0000001
    Address 61: Battery Regul. Labels: 4F0-910-181.lbl
    Part No SW: 4F0 910 181 F HW: 4F0 915 181 B
    Component: J0644 BEM H12 0760
    Revision: 00000000 Serial number: 00000000005068
    Shop #: WSC 00860 210 56227
    VCID: 24470A1BE72E243ED0B-8071
    Subsystem 1 - Part No: 4F0 915 105 D
    Component: von VA0 2801180527
    Coding: 344630393135313035442056413032383031313830353237
    Shop #: WSC 00000 512 00290
    Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
    Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
    Component: TSG HL H21 0210
    Coding: 0003074
    VCID: 2E53E833B9E29E6E36F-807B
    Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
    Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
    Component: TSG HR H21 0210
    Coding: 0003074
    Address 77: Telephone Labels: 4E0-910-336.lbl
    Part No SW: 4E0 910 336 M HW: 4E0 862 335
    Component: Handyvorb2 H18 1130
    Revision: 00000000 Serial number: 00000005083301
    Coding: 0010920
  4. Re: 5 fault codes showing, fuel gauge displays empty, 00438 - fuel supply sensor 2 (G169)
    134 Post(s)
    2022 Post(s)
    I will have to study the wiring diagram at work tomorrow.
  1. Fuel gauge showing empty... the usual fixes have not worked.
    By Goliath in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 14-12-2016, 03:43 PM
  2. Question Fuel gauge reading empty
    By colinrea in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 25-04-2016, 08:56 PM
  3. Please Help Fuel Gauge Stuck on empty?
    By toadeh in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-01-2014, 03:08 PM
  4. Fuel filled up but showing empty?!*
    By mikewGT in forum Golf MK6 - 2009 - 2013
    Last Post: 17-11-2010, 12:56 PM
  5. Fuel gauge shows empty
    By krishcanag in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 06-06-2009, 08:36 AM
