Thread: 2016 Passat boot stuck shut
Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
  1. Re: 2016 Passat boot stuck shut
    Feb 2020
    Bristol
    Thanks for the reply, i will give it a go.
  2. Re: 2016 Passat boot stuck shut
    Dec 2019
    Quote Originally Posted by Zangieff View Post
    I did end up fixing it myself . I bought a new boot lock from vw ( £50 or so)
    1. The lock was completely Stuck , I couldn’t remove it ( had to disassemble the boot from inside, had to take the black plastic off.
    2. If your lucky , the emergency boot release might still work( lift up the red emergency tab and use screw driver to open it.
    3 . You can skip part one if you can open the boot from inside.
    4. If u ain’t confident take it to a garage or vw
    Do you have the part number for it?
  3. Re: 2016 Passat boot stuck shut
    Nov 2019
    London
    Sorry I don’t have a part number, but if you give vw your reg they will give your the correct part. ( they might even give you the exploited view of the booot so you can easily fix it.
  4. Re: 2016 Passat boot stuck shut
    Dec 2008
    6 Post(s)
    well done that man !
  5. Re: 2016 Passat boot stuck shut
    Dec 2019
    Hi, i have the view, i was just curious if is the same part as skoda superb, as my boot starting playing up and seems to be very common issue with the passat b8 but seems i getting the same...
  6. Re: 2016 Passat boot stuck shut
    Sep 2018
    England
    My tailgate refused to unlock back in March. I tried to use the manual lever behind the tailgate trim but this didn’t work. After finding a YouTube video of the same problem it appears to be a common problem on these cars. It’s possible to remove the trim from the inside with the door closed this allows access to the lock which can be unbolted and the tailgate opened. I eventually released the seized lock but even using WD40 on it this would still stay closed so I ordered a replacement from VW new part number 5TA 827505 D at a cost of £56 this was fitted and I now have a tailgate that works ok. Be warned if your lock starts playing up and refuses to open order a new one other wise you might have locked tailgate.
  1. Passat Boot Lid Mechanism issue.. it won't stay shut!!!
    By Max-Power in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-01-2010, 01:35 AM
  2. Question glovebox stuck shut
    By zetectdci in forum Polo - Derby - Lupo - Fox
    Last Post: 03-02-2009, 10:10 PM
  3. Question Passat Boot won't shut
    By Maz in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-09-2008, 09:24 PM
  4. boot warning sensor comes on the display when the boot is shut
    By merchantmr in forum Audi A4 - Archive Topics
    Last Post: 06-02-2007, 10:04 PM
