Thread: MOT Fail - Engine Light -
Results 1 to 10 of 10
  1. Unhappy MOT Fail - Engine Light -
    Jan 2016
    North West UK
    Hi all,
    Long time no post.
    Just had my MOT - great timing for a FAIL just before Xmas.
    Here are the fails - 3 out of the 4 jobs aren't really a problem but the engine management light is the thing that bothers me most...
    I had the EGR valve cleaned and refitted a while back but the light only stays off for a short amount of time. Is there any way to permanently (or temporarily for a day) disable the light?
    Fail/Defects from MOT:-
    Engine MIL inoperative or indicates a malfunction
    exhaust has a major leak of exhaust gases
    suspension component mounting prescribed area excessively corroded significantly reducing structural strength NSR
    Anti roll bar linkage ball joint dust cover no longer prevents the ingress of dirt OSF
  2. Re: MOT Fail - Engine Light -
    131 Post(s)
    1976 Post(s)
    What is the engine code and the fault code?
  3. Re: MOT Fail - Engine Light -
    Apr 2017
    Grantham
    Sounds like the EML is the least of your worries
    0 0 1
  4. Re: MOT Fail - Engine Light -
    Jan 2016
    North West UK
    It's a BKC. EGR insufficient flow. Had it cleared but came back on after about an hour. It's already been taken off and cleaned.
  5. Re: MOT Fail - Engine Light -
    Jan 2016
    North West UK
    Quote Originally Posted by j_mack View Post
    Well now I've had the welding done and bought a replacement drop link I'd say it is my only worry. Thanks for your valuable input.
    1 1 0
  6. Re: MOT Fail - Engine Light -
    Apr 2017
    Grantham
    Quote Originally Posted by DannyBoyGolf View Post
    Painful amount of work but it’ll be worth it, just done the wings and mostly had the car resprayed/alloys refurbished to sort out everything that had corroded on my Gti, hope you get it sorted soon
  7. Re: MOT Fail - Engine Light -
    Jun 2016
    Glasgow
    Post engine scan in full with ambient data.
  8. Re: MOT Fail - Engine Light -
    131 Post(s)
    1976 Post(s)
    Cleaning the system is often not enough, it has to be removed from the head (including the manifold) and stripped clean with new parts.
  9. Re: MOT Fail - Engine Light -
    Apr 2017
    Grantham
    Did you get to the bottom of this one OP?
  10. Re: MOT Fail - Engine Light -
    Jan 2016
    North West UK
    hi, not got to the bottom of it yet. i managed to get the light reset & stayed out long enough to get through the MOT.
  1. Engine Redir fail
    By 590 tyres in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 30-03-2017, 06:58 PM
  2. Please Help Power steering fail battery light on
    By Ashleylawrence2 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 23-03-2015, 08:42 PM
  3. Engine Labels: Redir Fail - ASB engine
    By digger42 in forum VCDS - General Questions
    Last Post: 01-05-2014, 11:02 PM
  4. A4 B7 Air conditioning compressor - FAIL - Poss fail - Maybe fail - Has Failed
    By blackgrill in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 05-05-2012, 02:36 PM
