Thread: Panoramic sunroof leak?
Page 4 of 12 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 118
  1. Re: Panoramic sunroof leak?
    #31
    Oct 2019
    Sadly for me the Captain Tolleys fix didn’t sort it.
    Neither did a gallon of sealant from diy shop 🤪
    Took to a really helpful and friendly local indi who advised the wind deflected was not folding in properly, and by catching was slightly opening the seal allowing water ingress. Doesn’t answer it going into the headlining though.
    They couldn’t fix and despite a LOT of effort on their part (and only charging me £50 for over 4 hours of actual work not including the “hose time”) they sadly couldn’t help.
    Drains all running cleanly so had to bite the bullet and go to the mothership!
    Said needed a new cassette as the tensioning wires had “overstretched” and as an integral part of the cassette cannot be replaced on their own! £1800 less in my wallet and a few days in a nice S4 and I had my once again waterproof car back............ for 3 weeks and it only started again on the drivers side!!
    Tidy Q5 loan vehicle this times whilst it’s back in for a warranty repair this time! I’m absolutely livid after shelling out hat much to Audi - and believe me they know about it!
    Will post on here their remedy once known, but I’d for sure avoid the pan roof ever again after this experience.
  2. Re: Panoramic sunroof leak?
    #32
    Nov 2014
    Stafford
    8 Post(s)
    Same for me - Captains thing worked for about 2 months - then massive leaks
    also needed two rear electronic shocks at 800 a side plus the new sunroof cassette
    result = sold it - but still miss it
    Quote Originally Posted by RikNik View Post
  3. Re: Panoramic sunroof leak?
    #33
    Nov 2018
    Liverpool
    Quote Originally Posted by S8Man View Post
    Hello All.
    My 2014 A6 Allroad started leaking into the driver's footwell a few months back.Tried all the usual suspects - ecu cover,plenum etc etc - wallet £100's lighter but no joy.I am now trying Captain Tolley but wonder if I can shut the sunroof straight after applying the liquid - I am just concerned about gumming the roof shut !
    Just wondering how you guys did it.
    Thanks.
    ps. Audi main dealers......just seem to go from bad to worse these days.Can anyone suggest a good indie in the North West ?
    Couple of places iv used and are spot on, german car specialists based just over the mersey gateway bridge in runcorn and another one i used for my cambelt a place called unit20 which is based on the wirral
  4. Re: Panoramic sunroof leak?
    #34
    Jan 2016
    Merthyr Tydfil
    25 Post(s)
    Quote Originally Posted by cypermethrin View Post
    did you get this resolved afterwards?
  5. Re: Panoramic sunroof leak?
    #35
    Nov 2014
    Stafford
    8 Post(s)
    Quote Originally Posted by RhysoTDI View Post
    in addition to the leaking sunroof (1800 quid) it needed two rear electronic dampers at 800 quid each
    upshot was I sold it for a V60 which is a pile of sh*te and have regretted it ever since
  6. Re: Panoramic sunroof leak?
    #36
    Jan 2016
    Merthyr Tydfil
    25 Post(s)
    i quoted the wrong person! Meant to quote RikNik
    mine is doing my head in but when we get a dry day it’s never warm enough for the Captain Tolley to set properly
  7. Re: Panoramic sunroof leak?
    #37
    Nov 2017
    derry
    6 Post(s)
    I thought this too, but as someone stated above. Its tiny amounts each time layering it up. First couple of times for me it was just running on through and wouldnt set. The time it worked I used no more than 2ml from a syringe. From doing this mine has still not leaked. And I'm in ireland so not many dry days
    Sent from my SM-G950F using Tapatalk
  8. Re: Panoramic sunroof leak?
    #38
    Oct 2014
    England
    Well, after several months of not leaking, sadly my drivers footwell is wet once more, can see evidence of the leak by the bonnet release catch... Gutted.
    I've removed the wind deflector to see if that was affecting it, no change. So now it's time to try and seat everything with silicone sealant.
    Next step will be removing the head lining, but I need better weather for that.
    I take comfort in the fact its not just me suffering.... Sorry!
    Will report back later.
  9. Re: Panoramic sunroof leak?
    #39
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    Quote Originally Posted by rob-the-viking View Post
    ...can see evidence of the leak by the bonnet release catch... Gutted.
    Trying to be encouraging, could that be the roof gutter drain tube separated rather than actual roof leak? On our non-panaromaic VW roof I've just had the trim off the pillar and found the tube disconnected from the rubber boot / gaiter that goes into scuttle area to drain behind wheel arch. I've previously had it disconnected at the other end as well - the spigot from roof gutter. Both lead to water running down area behind dash.
  10. Re: Panoramic sunroof leak?
    #40
    Aug 2013
    East Yorkshire
    7 Post(s)
    I really feel for anyone with wet in the footwells and would like to add a word of warning. There are electrical and electronic control boxes under the carpets. I had to write off a C6 as uneconomic to repair (admittedly 9 years old) due to corrosion of the wiring loom and faults in control boxes caused by water ingress in the footwells.
    Don't just stop the water ingress, but look for, or get other consequences covered as well.
    John.
  1. Panoramic sunroof leak
    By 172cup in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 26-10-2018, 11:51 AM
  2. Panoramic sunroof issues
    By sabai dee in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 01-03-2015, 12:41 PM
  3. Please Help Possible leak from panoramic sunroof.
    By makemineamythos in forum Golf MK5 - 2004 - 2009
    Last Post: 02-04-2014, 08:34 PM
  4. Anyone got a Panoramic Sunroof?... Worthwhile?
    By thehorse in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 11-06-2012, 10:32 PM
  5. Panoramic sunroof owners
    By SunnyBard in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 18-06-2011, 05:51 PM
