Thread: Coolant leak - Culprit is the Coolant inlet valve seal
Page 10 of 12 FirstFirst ... 89101112 LastLast
Results 91 to 100 of 114
  1. Re: Coolant leak - Culprit is the Coolant inlet valve seal
    #91
    Apr 2013
    donadea co kildare
    I've not seen that one for years, it may be superceded. There's no definitive source of Audi TSB that's easily searchable. This is the largest source I've found, but it's a trawl to go through every page for every model and year using 'find in page' using 'coolant or 'leak. TSB numbers seem to make no sense, or are in any particular alphanumeric order.
    AUDI A6 Factory Technical Service Bulletin - TSB | AutoCodes.com
    Edit. That TSB couldn't be found January 2020, it may never have been published on a web site. An earlier poster refers to ' internal Audi TPI', which was probably an audi state secret, only available on the audi service system. Those other TSBs describe the exact condition, if not the correct range of cars to which it applies. Read the earlier posts re warranty refusals, where they contend that the failure was a long developing natural wear and tear issue, not a design disaster waiting to happen. The work on my car is unrecorded on the Audi service record for the car. No parts, labour, work descriptions. Very fishy
  2. Re: Coolant leak - Culprit is the Coolant inlet valve seal
    #92
    1840 Post(s)
    Quote Originally Posted by folkwagen View Post
    https://erwin.audi.com/erwin/showHome.do
  3. Re: Coolant leak - Culprit is the Coolant inlet valve seal
    #93
    Aug 2022
    Here
    Absolutely I was thinking the same yesterday after I seen some of the comments.
    Thank you again
  4. Re: Coolant leak - Culprit is the Coolant inlet valve seal
    #94
    Apr 2013
    donadea co kildare
    You wouldn't have a generic username and password for that ERWIN server by any chance?
  5. Re: Coolant leak - Culprit is the Coolant inlet valve seal
    #95
    1840 Post(s)
    You create your own account.
  6. Re: Coolant leak - Culprit is the Coolant inlet valve seal
    #96
    Apr 2013
    donadea co kildare
    What does it cost to use, by time or by document? Audi wanted €100 off me just to use their scanner to see if there were any codes relating to the leak (there weren't as I already knew). Said using the scanner wasn't covered under extended warranty! Talk about trying it on. They obviously were talking about fees for looking up TSBs or service procedures. I refused, I sent them the TSB. A big main dealers, they must have had some of these failures in by then, Jan 2020.
  7. Re: Coolant leak - Culprit is the Coolant inlet valve seal
    #97
    1840 Post(s)
    It costs €7 an hour to access the dealer level system ELSA PRO and all the TSB's relating to the VIN entered in what we call the "Red Book". There can never be codes relating to the valve itself as it is vacuum operated and has no feedback.
  8. Re: Coolant leak - Culprit is the Coolant inlet valve seal
    #98
    Apr 2013
    donadea co kildare
    The valve that caused the TCU failures was electrical, coolant got out from the valve body via the electrical pins, leaking into the loose fitting cable shroud, hopefully out onto the bottom cover, but in many cases it continued on up the inside of the shroud to the main loom, and from there into the TCU multipin connector, ruining this and even the TCU board itself. Thousands of bucks. It may also have wicked to other controllers and caused havoc. If the loom shrouds were well sealed at the connector collars, you might be hard set to find a drip, as all the coolant was inside the loom and oozing out into critical sealed electrical components. By the time you got codes, you were in big trouble. A few posters on other blogs managed to salvage the situation without losing their Transmission CU.
  9. Re: Coolant leak - Culprit is the Coolant inlet valve seal
    #99
    1840 Post(s)
    I thought you were dealing with the valve in the V leaking?
  10. Re: Coolant leak - Culprit is the Coolant inlet valve seal
    Aug 2022
    Here
    I’m after the valve in the engine V too
  1. Coolant leak through EGR valve V6 3.0 quattro TDI
    By Audijager in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 10-06-2016, 03:21 PM
  2. Question Coolant leak from rear flange: Sourcing the coolant pipe?
    By defever in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-09-2015, 11:36 AM
  3. Question 1999 A4 2.8 quattro 2.8 - coolant leak under inlet manifold
    By timmyp666 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 12-02-2015, 05:49 PM
  4. Replies: 8
    Last Post: 19-04-2012, 06:43 PM
  5. Please Help Coolant Leak From Coolant\Water pump Housing
    By Chappio in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-04-2009, 03:30 PM
