Thread: Coolant leak - Culprit is the Coolant inlet valve seal
Page 11 of 12 FirstFirst ... 9101112 LastLast
Results 101 to 110 of 114
  1. Re: Coolant leak - Culprit is the Coolant inlet valve seal
    2007 Post(s)
    Well as I said, that has no feedback and my rule with this engine is "water loss, change the valve"; you could over analyse the problem for weeks only to come to the same conclusion.
  2. Re: Coolant leak - Culprit is the Coolant inlet valve seal
    Jul 2023
    London, UK
    So appears I have the same issue (Q7 4M 2016 3.0 TDI). Had it at dealers recently to change glow plugs and asked if they would take a look down in the V for coolant and they said they could see it. I'm in SE London/NW Kent. Can anyone recommend a specialist indie for this job? Don't mind travelling outward a bit for a good recommendation.
  3. Re: Coolant leak - Culprit is the Coolant inlet valve seal
    2007 Post(s)
    Cheap part, just that it takes hours to fit.
  4. Re: Coolant leak - Culprit is the Coolant inlet valve seal
    New Forest
    80 Post(s)
    Quote Originally Posted by webego View Post
    Unrelated to the coolant valve (mine has been fine since being changed) what was the £labour time for the glow plugs? My engine light has come on, for 2 x glow plugs.
    Sent from my SM-G965F using Tapatalk
    Q7 3.0 TDI Quattro (272 HP) S-Line
    (Gone) A6 C6 AVANT 2.7TDI SE MANUAL
    Hers - Mk. VII Golf '15' 2.0 TDI BlueMotion
  5. Re: Coolant leak - Culprit is the Coolant inlet valve seal
    2007 Post(s)
    It isn’t so much the time taken to change the plugs but the shear sphincter clenching gas inducing creak, rattle, squeal and squeak of each turn of the plug during removal that strikes fear into the mechanics underwear. Once we had all six snap the end off the plug and just sit there giving us the finger.
  6. Re: Coolant leak - Culprit is the Coolant inlet valve seal
    New Forest
    80 Post(s)
    So I understand Crasher. Soaking them in Plusgas or DERV is supposed to help (I'm reliably informed)
  7. Re: Coolant leak - Culprit is the Coolant inlet valve seal
    Jul 2023
    London, UK
    I only had a fault on one plug but decided to get all six changed as I was going to pay the dealers to do it. No issues, took less than 2 hours (while I waited) for just shy of £400 all in. Thought about doing it myself but bottled it for the above mentioned reasons.
  8. Re: Coolant leak - Culprit is the Coolant inlet valve seal
    Jul 2023
    London, UK
    So nobody had this valve replaced by an indie in the South East? Also curious of costs incurred anywhere in the UK to be honest to get a ball park idea of non dealer prices.
  9. Re: Coolant leak - Culprit is the Coolant inlet valve seal
    Oct 2010
    Lancaster
    Hi Crasher
    I have just bougt a Q7 and the coolant bottle is going down. After a lengthy journey I can smell coolant on opening the bonnet. I have pressurised the system and boroscoped everything. Its all dry, no witness on the shut off valve. V comp;letely dry, no drips coming down from V. The undertray is wet with coolant. No drips. The top of the sump is wet right under that valve you posted. I thinkit must be either the valve or the housing.
    Did you get to the bottom of your leak? If this valve is oil pump pressure valve then I guess it cant be that.
    thanks in advance
    Q7 272PS, Tech, Dyn, Trailer, Drv/Pass Mem Seats, NightV, Bose, Soft doors,Heat+Snd glass, Prv Glass, Heat W/Screen, Adv Key, Elec Boot cover, Elec Steering Col, Side Assist, Air Susp, Amb light, Heat fold mirrors, Adv Park Assist, Adv TPMS, Pan Rf, Kufatec, Rear Steer, Style Pack, City Pack, Tour Pack, Htd rear seats, 4 Zone, Black Pack
  10. Re: Coolant leak - Culprit is the Coolant inlet valve seal
    2007 Post(s)
    We have had some where the water pump gasket corrodes and allows a small leak you cannot see.
  1. Coolant leak through EGR valve V6 3.0 quattro TDI
    By Audijager in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 10-06-2016, 03:21 PM
  2. Question Coolant leak from rear flange: Sourcing the coolant pipe?
    By defever in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-09-2015, 11:36 AM
  3. Question 1999 A4 2.8 quattro 2.8 - coolant leak under inlet manifold
    By timmyp666 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 12-02-2015, 05:49 PM
  4. Replies: 8
    Last Post: 19-04-2012, 06:43 PM
  5. Please Help Coolant Leak From Coolant\Water pump Housing
    By Chappio in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-04-2009, 03:30 PM
