Thread: Glow plug light flashing
Threaded View
  1. Re: Glow plug light flashing
    Sep 2019
    Belgrade & Serbia
    Here is why it might be happening. The electric pump inside the tank might not working. I don't know about that exact model but the system is similar with most newer cars of the VW, Audi, Seat, Skoda etc... So, it could be that the electric pump doesn't fill the inner tank housing as it should (it has about 1,5ltr of fuel inside itself). That inner housing is where the high pressure pump is sucking fuel from. It has to be full of fuel always. Think of it as a little fuel tank fitted within a huge fuel tank. That little tank has a fuel level sender (FLS, designation G210) placed inside - when fuel level is lower than it should be it changes the resistance and thus it sends the signal to ECU which turns glow plug warning light on/off. So you get a flashing glow plug light. Check the fuse for the electric pump. Also it may be that the wires that go to the FLS are just loose but that's quite a rare cause... By the way, it also may be something wrong with the seals in the housing, some leak, so when you rev more, the engine sucks more fuel and the inner housing empties faster than it is filled with fuel and so when fuel level drops the FLS activates flashing light.
    Tell me what you have found there.
  1. Glow plug light flashing.
    By DrNorthy in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 18-01-2016, 09:47 PM
  2. Flashing glow plug light.
    By rplc1976 in forum Golf MK4 - 1999 - 2004
    Last Post: 26-11-2014, 08:18 AM
  3. Flashing glow plug light
    By westfield1962 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-12-2012, 12:19 PM
  4. Please Help Glow plug light flashing
    By happydan in forum A8 - S8 - V8
    Last Post: 12-02-2012, 09:17 PM
  5. Glow Plug Light Flashing
    By mac78 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 16-12-2008, 01:41 PM
