Thread: Attempted Steering lock repair
  1. Attempted Steering lock repair
    Aug 2010
    St. Austell, Cornwall
    I received eBay components on Saturday, a tiny relay, 3 x microswitches and two little levers, to sort out the steering lock actuator fault.
    So I thought Sunday was a good time to try fitting them.
    It was fiddly getting the old components off the PCB, as they seemed to be stuck down with lacquer, but with a lot of swearing I installed the new bits.
    When back in the car, I can hear the steering lock actuating, so was very hopeful that I’d sorted it.
    Unfortunately, I get nothing when trying to start the car. All dashboard lights come on, steering lock disengages, but it won’t turn over.
    Is the immobiliser contained on the same PCB? Have I buggered it in my incompetence?
    Any ideas would be gratefully received!
  2. Re: Attempted Steering lock repair
    Jul 2013
    76 Post(s)
    Have you cleared any fault codes as the steering column has been removed.
    If so then you could have damaged a component or track on the PCB when you scrapped off the conformal coating.
    Dan
    2017 Q5 S LINE QUATTRO 190 BHP
  1. Steering Lock Repair Price - Are VW honouring it?
    By diesel2000 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 08-03-2018, 07:01 PM
  2. steering rack repair
    By helmsy157 in forum 80 - 90
    Last Post: 11-04-2017, 10:44 AM
  3. quattro lock repair question(s)
    By d4zzy in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 07-08-2016, 03:41 PM
  4. Question Passat B5.5 Estate needs tailgate microswitch and rear passanger door lock repair
    By berrick in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-02-2014, 11:50 AM
  5. Lupo door lock repair
    By davidsaglover in forum New Member Introductions
    Last Post: 08-12-2011, 09:11 AM
