Thread: Wheel size
  1. Question Wheel size
    Jun 2010
    Oxfordshire
    Hi, need some advise. My wife bought a 2010 VW Beetle with 205/55/R16 wheels/tyres. I am selling a 2004 Passat with a set of 195/60/R15 winter tyres. Will these be ok to use on the Beetle or are there fitting/insurance implications? I will keep them for the Beetle if they are suitable. Thanks
  2. Re: Wheel size
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    PCD will be ok but you need to check the ET or offset, this is cast into the wheel on the inside of the spokes or the front around the bolt holes. I used to interchange a set of 16" golf MK5 alloys with ET50mm onto my B5 passat (likely the same as your passats ET37 15" ) for winter, so the golf wheels sat 13mm further inside the arch but I never had any problems with clearance. If the 2010 beetle wheels are ET 50mm you will find the passat ET37mm wheels will stand out from the arches a bit, maybe not ideal in winter! and unless you have big calipers and discs and they wont fit, the 15" wheels will run closer to the beetles calipers than the 16" originals. No comment regarding insurance, some say you need to inform them, I doubt if many people actually do.
  3. Re: Wheel size
    Jun 2010
    Oxfordshire
    Rob. Thank you very much for your suggestion. I will check it later....
  1. New Q7 Wheel Size
    By Q7newbie in forum Q7 - 4M Forum - 2016 -
    Last Post: 29-05-2016, 12:12 AM
  2. Question wheel size
    By maccayzf in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 13-05-2016, 01:51 PM
  3. A3 190hp . What wheel size, what tyres size would you buy
    By MR2BIG in forum Wheels and Tyres
    Last Post: 08-09-2015, 09:44 PM
  4. Wheel Size
    By andywell in forum Golf MK5 - 2004 - 2009
    Last Post: 15-01-2010, 03:01 PM
  5. Appropriate wheel size
    By Thunderbeast in forum Bora - 1998 - 2005
    Last Post: 29-12-2009, 04:40 PM
