Thread: Lit up like a christmas tree
Results 1 to 10 of 11
  1. Lit up like a christmas tree
    Dec 2014
    West Sussex
    I'm hoping somone can offer some assistance on this. My 2011 2.0tdi A6 just decided to go crazy!
    I got in the car this afternoon to drive home, got out onto the main road and a warning light popped up on the dash, 'sterring defective do not drive'
    Now it's not the first time this has come up, normally it goes away and doesn't come back. The last time it did it was about this time last year.
    But this one didn't go, and when I got home i plugged into VCDS for a quick scan, it brought back a load of errors, after some advice on the best place to start.
    Tuesday,16,October,2018,17:03:45:62939
    VCDS -- Windows Based VAG/VAS Emulator
    VCDS Version: Release 12.12.0 (x64)
    Data version: 20130910
    Dealer/Shop Name: abc
    Workshop Code: 123 12345 000000
    VIN: WAUZZZ4G7BN023268 License Plate:
    Chassis Type: 4G (4G0)
    Scan: 01 03 05 08 09 0E 10 15 16 17 19 28 3B 42 44 46 52 53 55 5F
    62 72
    01-Engine -- Status: Malfunction 0010
    05-Acc/Start Auth. -- Status: OK 0000
    0E-Media Player 1 -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    28-HVAC, Rear -- Status: OK 0000
    3B-Sensor Elect. -- Status: OK 0000
    44-Steering Assist -- Status: Cannot be reached 0100
    53-Parking Brake -- Status: OK 0000
    55-Xenon Range -- Status: OK 0000
    5F-Information Electr. -- Status: OK 0000
    Address 01: Engine (J623-CGLC) Labels: 03L-906-018-CGL.clb
    Part No SW: 03L 906 018 LA HW: 03L 906 018 JL
    Component: R4 2,0L EDC H23 0756
    Revision: 45H23---
    Coding: 0A194012242401080000
    Shop #: WSC 14519 002 1048576
    ASAM Dataset: EV_ECM20TDI01103L906018LA 003005
    ROD: EV_ECM20TDI01103L906018GT.rod
    VCID: 74E73A5BDF4EF4BE80B-8021
    2 Faults Found:
    4698 - Function Restriction due to Faults in Other Modules
    U1113 00 [039] - -
    Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 6
    Fault Frequency: 2
    Mileage: 172283 km
    Date: 2018.10.16
    Time: 16:46:40
    4699 - Function Restriction due to Faults in Other Modules
    U1113 00 [039] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 2
    Mileage: 172283 km
    Date: 2018.10.16
    Time: 16:46:40
    Readiness: 0 0 0 0 1
    Address 03: ABS Brakes (J104) Labels: 4G0-907-379.clb
    Part No SW: 4G0 907 379 HW: 4G0 907 379
    Component: ESP PREMIUM H08 0190
    Revision: -------- Serial number: --------------
    Coding: 06A087006005E1009B00
    Shop #: WSC 02311 785 00200
    ASAM Dataset: EV_ESPPremiAU57X 003013
    ROD: EV_ESPPremiAU57X.rod
    VCID: EED3A83331625E6EF6F-80BB
    3 Faults Found:
    0674 - Function Restricted due to Missing Message(s)
    U1111 00 [009] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 235
    Mileage: 172283 km
    Date: 2018.10.16
    Time: 16:52:58
    0469 - Function Restricted due to Missing Message(s)
    U1111 00 [009] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 235
    Mileage: 172283 km
    Date: 2018.10.16
    Time: 16:52:58
    0788 - Control Module Incorrectly Coded
    U1014 00 [145] - -
    MIL ON - Not Confirmed - Not Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 235
    Mileage: 172283 km
    Date: 2018.10.16
    Time: 16:52:58
    Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
    Part No SW: 4H0 907 064 AN HW: 4H0 907 064 AN
    Component: BCM2 2.0 H24 0217
    Revision: 00002001
    Coding: 03B83000000000000000
    Shop #: WSC 02391 785 00200
    VCID: 75E1075FDC34EDB6B75-8020
    Subsystem 2 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
    Component: J764 ELV MLB H38 0044
    No fault code found.
    Address 08: Auto HVAC (J255) Labels: None
    Part No SW: 4G0 820 043 K HW: 4G0 820 043 K
    Component: KLIMA 4 ZONEN H11 0056
    Serial number: 30031100040132
    Coding: 34210078A0
    ASAM Dataset: EV_AirCondiComfoUDS 002029
    ROD: EV_AirCondiComfoUDS.rod
    VCID: 275D1D175E18CF26F59-8072
    Address 09: Cent. Elect. (J519) Labels: 4H0-907-063.clb
    Part No SW: 4H0 907 063 N HW: 4H0 907 063 F
    Component: BCM1 2.0 H12 0092
    Revision: 20012002 Serial number: 00000001006787
    Coding: 2600201141349F600481008300001D0CCF9D83082709010100 0008602100
    Shop #: WSC 58029 001 104857
    VCID: 3365F94792C0B386591-8066
    Subsystem 1 - Part No SW: 4G2 955 119 HW: 4G8 955 119 A
    Component: WWS57X 110224 H32 0051
    Coding: 0045F7
    Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
    Component: RLS H04 0003
    Coding: 02512B
    Subsystem 3 - Part No SW: 4G0 941 531 E HW: 4G0 941 531 E
    Component: E1 - LDS H07 0044
    Subsystem 4 - Part No SW: 4H0 907 658 HW: 4H0 907 658
    Component: AQ_Hum_Sensor H02 0002
    1 Fault Found:
    01309 - Power Steering Control Module (J500)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 235
    Mileage: 172283 km
    Time Indication: 0
    Date: 2018.10.16
    Time: 16:55:00
    Address 0E: Media Player 1 (R41) Labels: Redir Fail!
    Part No SW: 8X0 035 110 C HW: 8X0 035 110
    Component: CDC-MP3-Pana H41 0490
    Revision: 00000006
    VCID: 2D51EF3F74E4E5760F5-8078
    Address 10: Park/Steer Assist (J446) Labels: 4H0-919-475-7X2.clb
    Part No SW: 4H0 919 475 H HW: 4H0 919 475 C
    Component: PARKHILFE ACC H07 0030
    Revision: 11001001 Serial number: 55901106600049
    Coding: 100205
    ASAM Dataset: EV_EPHVA18AU57X0000 001002
    ROD: EV_EPHVA18AU57X0000.rod
    VCID: 377DCD578EB85FA6659-8062
    Address 15: Airbags (J234) Labels: None
    Part No SW: 4H0 959 655 C HW: 4H0 959 655 C
    Component: Airbag10.43 H40 0040
    Revision: -------- Serial number: 003JG001YTR0
    Coding: 30323436313230303235554A305234473053
    ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
    ROD: EV_AirbaAU10BPAAU64X_AU57.rod
    VCID: 3663C05389B2A6AE7EF-8063
    Crash sensor for side airbag; driver side:
    Serial number: 3575HRB406109REC80G0
    Crash sensor for side airbag; passenger side:
    Serial number: 3585HRB40610CE323OIY
    Crash sensor for side airbag; rear driver side:
    Serial number: 3515JRB40630G2I2E0V
    Crash sensor for side airbag; rear passenger side:
    Serial number: 3525JRB40650G2I2OH3/
    Crash sensor for front airbag; driver side:
    Serial number: 3554VRB40690ESAS291P
    Crash sensor for front airbag; passenger side:
    Serial number: 3564VRB40690ESASI0RG
    Address 16: Steering wheel (J527) Labels: None
    Part No SW: 4G0 953 568 A HW: 4G0 953 568 A
    Component: Lenks.Modul H05 0201
    Revision: 00000000 Serial number: 20161111000122
    Coding: 000014
    Shop #: WSC 58029 001 1048576
    VCID: 306FF64B63D6889E243-8065
    Subsystem 1 - Part No SW: 4G0 951 528 C HW: 4G0 951 528 C
    Component: E221 - MFL H07 0009
    Address 17: Instruments (J285) Labels: 4H0-920-xxx-17.clb
    Part No SW: 4G8 920 981 C HW: 4G8 920 981 C
    Component: TDieGb H34 0312
    Revision: 19100074 Serial number: 658140311593022
    Coding: 33A508000B012600010000
    ASAM Dataset: EV_RBD4K 004033
    ROD: EV_RBD4K.rod
    VCID: 3365F9479AC0B386591-8066
    1 Fault Found:
    16776978 - Function Restricted due to Missing Message(s)
    U1111 00 [009] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 235
    Mileage: 172283 km
    Date: 2018.10.16
    Time: 16:56:15
    Address 19: CAN Gateway (J533) Labels: None
    Part No SW: 4G0 907 468 C HW: 4G0 907 468 A
    Component: J533--Gateway H08 0204
    Revision: -------- Serial number: 00000000124490
    Coding: 00CD074400
    ASAM Dataset: EV_GatewUDS 001025
    ROD: EV_GatewUDS_AU57.rod
    VCID: 306FF64B6BD6889E243-8065
    Battery Monitoring Control Module:
    Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
    Component: J367-BDM H07 0140
    Serial number: 00000000005650814555
    Voltage stabilizer:
    1 Fault Found:
    4906 - Power Steering Control Module
    U101D 00 [009] - No Communication
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 235
    Mileage: 172283 km
    Date: 2018.10.16
    Time: 16:57:25
    Address 28: HVAC, Rear (E265) Labels: 4G0-919-158.clb
    Part No SW: 4G0 919 158 C HW: 4G0 919 158 C
    Component: KLIMA FOND H07 0056
    Serial number: 29031100040439
    Coding: 02
    ASAM Dataset: EV_ClimaContrUnitRearUDS 002012
    ROD: EV_ClimaContrUnitRearUDS.rod
    VCID: 2F6DF53776E897663D9-807A
    Address 3B: Sensor Elect. (J849) Labels: 4G0-907-637.clb
    Part No SW: 4G0 907 637 HW: 4G0 907 637
    Component: SARA 3D H02 0004
    Revision: -------- Serial number: EJ1BPA32003C7L0
    Shop #: WSC 00000 000 00000
    ASAM Dataset: EV_SARA 006014
    ROD: EV_SARA.rod
    VCID: EBD5A1270270AB46D11-80BE
    Address 42: Door Elect, Driver (J386) Labels: None
    Part No SW: 4G8 959 793 C HW: 4G8 959 793 A
    Component: TSG FA H04 0210
    Coding: 011F06204001620002080002
    Shop #: WSC 02312 785 00200
    VCID: 408FA68BD376181ED43-8015
    Address 44: Steering Assist
    Cannot be reached
    Address 46: Central Conv. (J393) Labels: 4H0-907-064-46.clb
    Revision: 00002001 Serial number: 0146934903
    Coding: 011B062200B904408320080400010000000000000000000000 0000000000
    Subsystem 1 - Part No: 4G0 951 177
    Component: DWA-Sensor H01 0010
    Subsystem 2 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HO H05 1501
    Address 52: Door Elect, Pass. (J387) Labels: None
    Part No SW: 4G8 959 792 C HW: 4G8 959 792 A
    Component: TSG BF H04 0210
    Coding: 011F06204401620002080002
    VCID: 3F8DA577AE8867E6AD9-806A
    Address 53: Parking Brake (----) Labels: 4H0-907-801.clb
    Part No SW: 4H0 907 801 E HW: 4H0 907 801 A
    Component: EPB-4 H03 0012
    Revision: -------- Serial number: 00000000055464
    ASAM Dataset: EV_ParkiBrake 001022
    ROD: EV_ParkiBrake_AU48.rod
    VCID: 2A5BE4234D0AF24EEA7-807F
    Address 55: Xenon Range (J431) Labels: None
    Part No SW: 4H0 907 357 A HW: 4H0 907 357 A
    Component: ....LWR12.... H02 0013
    Serial number: 110330-0004-018
    Coding: 112196101000A300
    ASAM Dataset: EV_HeadlRegulBasic 005001
    ROD: EV_HeadlRegulBasic.rod
    VCID: 2C57E23B47FEEC7E18B-8079
    Address 5F: Information Electr. (J794) Labels: None
    Part No SW: 4G0 035 193 P HW: 4G0 035 193 B
    Component: RMC Cnct Nav H50 0818
    Coding: 0101000001C15B47002B060301010000000000
    Subsystem 1 - Part No: 8X0 919 884 C
    Component: P11-50-10.06 1006
    Subsystem 2 - Part No SW: 4G0 919 603 HW: 4G0 919 603
    Component: DU6 Basic H42 0084
    Subsystem 3 - Part No SW: 4G2 919 710 B HW: 4G2 919 615 K
    Component: E380 BDT C7 H08 0204
    Address 62: Door, Rear Left (J388) Labels: None
    Part No SW: 4G8 959 795 C HW: 4G8 959 795 A
    Component: TSG HL H03 0210
    Coding: 010F04204001620002080002
    VCID: 428BAC83DD7A0A0EC27-8017
    Address 72: Door, Rear Right (J389) Labels: None
    Component: TSG HR H03 0210
    Any help greatly appreciated...
  2. Re: Lit up like a christmas tree
    Jan 2013
    Wessex. and Southern France
    114 Post(s)
    Two questions;
    How old's the battery?
    had any water ingress?
  3. Re: Lit up like a christmas tree
    Dec 2014
    West Sussex
    The battery is as old as the car, never been replaced. But I've not noticed anything battery related like poor starting or other odd errors.
    Water wise, not as far as I can tell, pointer on where to look? However it does seem to have shown itself shortly after all this rain we've just had??
    Thanks,
    Iain
  4. Re: Lit up like a christmas tree
    Jul 2018
    Waterford
    9 Post(s)
    Not good news and no other way of saying it......I got that message before on my last A6 (2013 model) and I got it checked by Audi. The message was intermittent and they couldn't find any fault but said I might need a new steering rack if it came back. It did come back and it got worse. I could lose power assistance when driving along...out of the blue...but then it would disappear for weeks and all would be ok.
    I traded the car against an Ultra (dealer knew of the issue) but the new owner ended up getting a new rack after a couple of months. Think it was about 2k...
    There are a few threads on this on the forum.
  5. Re: Lit up like a christmas tree
    Dec 2014
    West Sussex
    'Hangs head and begins to cry...' This was what i was hoping wasn't the problem. It's been on and off for a while, it just goes away, I can clear the DTC codes and all is good again, but then it, as you said, just comes back out the blue. Sometimes it come back for all of about 2 seconds, but like today it came on and didn't want to go away.
    I was hoping it was a module or loose wire, but I have a feeling this times it's more.
    What I find so strange is that the car is perfect before, no warning, no funny noise, nothing. It just pops up and causes the loss of power steering, tpms and something else. If it was mechanical I would have thought it wouldn't go away like it does, which points to bad sensors or wiring....
    Maybe it is time to part ex....but I'd feel bad selling it knowing the next owner will inherit the problem!
  6. Re: Lit up like a christmas tree
    Jul 2018
    Waterford
    9 Post(s)
    Sounds exactly like mine unfortunately alright. Damn expensive if not under warranty too.
    Mine might disappear for a couple of months but then come back. The dodgy bit was when I'd lose steering assistance unexpectedly in a car park or somewhere. ...
  7. Re: Lit up like a christmas tree
    Jul 2016
    Chestfield kent
    81 Post(s)
    Hi. Don't know it this would relate to your car or not, my FL late 2015. Had a recall done at around 9 months for a steering rack moisture check. So that know there may be an issue with some racks Might be worth trying to find out if yours falls into this recall.
    2015 FL S-line 2L ultra & 2003 225 TT Coupe
  8. Re: Lit up like a christmas tree
    Mar 2014
    Cologne, Germany
    55 Post(s)
    My previous had a similar issue (2014). Was driving along, never missed a beat, suddenly, message after message popped up. Basically everything like steering faulty, lane assist not working, brakes faulty etc etc. the whole package! Stopped the car. Restarted engine. All messages came back within a minute or two. Then attended a meeting for an hour, came back in the car and messages never showed up. In fact they never showed up again!
    My dealer was very confused as the car didnt show anything on the log either!
    Makes no difference now, sold it in 2017 and all is well afaik.
    2017 Audi S6 Avant
    2016 Volvo XC60 T5 R-Design (wife's)
    1987 Volvo 780 Bertone (my classic!)
  9. Re: Lit up like a christmas tree
    Dec 2014
    West Sussex
    Thanks all for the replies. As it always did, it popped back up again on the way home, wouldn't go away. But it was a damp and wet night. Took the car out in the morning for a good drive in the dry and the lights went away. Was driving past my local Audi so popped in, they were as confused as the rest of us, but said basically sounds like a steering rack and other bits... Asked about the recall on the rack for misture and got nonthing?
    So i've fixed the problem this morning by part exing the car for an A8... Must say i've always quite fancied one.
    Not sure it's going to be a long term relationship, it's a nice car, but with the kids growing up quick we won't need something this big for long.
    Thanks again all that helped.
  10. Re: Lit up like a christmas tree
    Jul 2016
    Chestfield kent
    81 Post(s)
    Like it. Can't fix it so Upgrade... The A8 is a real bargain second hand. Good for you, enjoy...
  1. Console lights up like a Christmas tree
    By Canada Bob in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 09-01-2014, 10:12 PM
  2. Please Help Dash like a christmas tree please help
    By macp in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 03-11-2011, 12:02 PM
  3. Please Help Dashboard Lights Up Like a Christmas Tree. Why?
    By Muttley60000 in forum Leon
    Last Post: 13-05-2009, 08:23 PM
  4. Please Help christmas tree dashboard
    By heybertuk in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 24-02-2009, 02:12 PM
  5. Attention Show us your Christmas Tree
    By MalcQV in forum Chat - Completely Off Topic
    Last Post: 11-12-2008, 07:46 PM
