Thread: MK5 Golf (2004) immobiliser kicking in no display on dash / cluster
Results 1 to 10 of 10
  1. MK5 Golf (2004) immobiliser kicking in no display on dash / cluster
    May 2018
    Blackpool England
    Hi all,
    Help would be much appreciated with my Golf MK5 (2004) 2.0 GT TDI (BKD)
    Came out to start my car this morning, as I got in and put the key in ignition and turned it I noticed the dash wasn't coming on and I mean absolutely nothing - no time, no odometer, no warning lights such as oil temp etc. absolutely nothing, not even the fuel gauge moved.
    I then went to start the car and it turned over and started for about 1 second then cut out which I assume is the immobiliser kicking in because there is no communication with the cluster to tell it its successfully handshaked with the key chip and the main ECU (please correct me if I'm wrong).
    Anyway I called out breakdown and the guy took my cluster out and said I was getting 12v to the cluster but that's as far as his diagnostics go.
    So I'm thinking my cluster unit is goosed, would you agree? If so what do I do now and is there anything else I can check prior to sending it off for repair, as in relays etc.
    I've got a guy coming tonight to plug a vag-com in so I'll update you with the codes but I'm thinking it wont be too telling as the cluster is down, is there a way I can power the cluster up on a bench to check its basic powering up???
    One last thing, the only thing I did before this happened is to mess with a bulb which seemed to have a dodgy connection on the back registration plate with the ignition on, Im highly doubting this but could this have caused any serge or damage???
    Please forgive me as my knowledge is limited but I try and learn as best I can.
  2. Re: MK5 Golf (2004) immobiliser kicking in no display on dash / cluster
    Mar 2018
    GB
    19 Post(s)
    Ignition on can pop fuses, check all the relays and fuses you can find.
    Sent from my SM-G950F using Tapatalk
  3. Re: MK5 Golf (2004) immobiliser kicking in no display on dash / cluster
    Mar 2018
    GB
    19 Post(s)
    Could also try disconnecting the battery for about 10 minutes helps reset the ecu.
  4. Re: MK5 Golf (2004) immobiliser kicking in no display on dash / cluster
    134 Post(s)
    2022 Post(s)
    Possibly low battery, the way modern cars respond is throwing people as it is not as it were int olde days.
  5. Re: MK5 Golf (2004) immobiliser kicking in no display on dash / cluster
    May 2018
    Blackpool England
    I can't believe it, got home and tried it again and it fired up first time cluster back fully working. Im so glad however concerned it might happen again. Anyhow plugged the vag com in and the following faults were in the history:
    18058 - Powertrain Data Bus
    P1650 - 000 - Missing Message From Instrument Cluster - Intermittent
    17978 - Engine Start Blocked By Immobiliser
    P1570 - 000 - Intermittent
    17949 - Fuel Pump Relay (J17)
    P1541 - 000 - Open Circuit
    00778 - Steering Angle Sensor (G85)
    000 - -
    Does this point to an intermittent fault with the cluster? Hopefully it won't come back!
  6. Re: MK5 Golf (2004) immobiliser kicking in no display on dash / cluster
    May 2018
    Blackpool England
    Could it really be a low battery if the car was cranking and starting?? I mean surely if the car can start it can power the cluster!
  7. Re: MK5 Golf (2004) immobiliser kicking in no display on dash / cluster
    134 Post(s)
    2022 Post(s)
    I see it all the time, modern starters can crank an engine over on a flat battery but everything else shuts down. As it recovered even more says battery, I would not be surprised if it was the original.
  8. Re: MK5 Golf (2004) immobiliser kicking in no display on dash / cluster
    May 2018
    Blackpool England
  9. Re: MK5 Golf (2004) immobiliser kicking in no display on dash / cluster
    May 2018
    Blackpool England
    That is very interesting, thank you very much, I will charge it up and do some battery tests on it
  10. Re: MK5 Golf (2004) immobiliser kicking in no display on dash / cluster
    Sep 2017
    Tyrone
    Sorry for using your thread butt I'm having a similar issue with my Jetta of the same era, however it is starting and driving perfect! Have the codes below:
    Faulty clocks? - No rev or speedo, lots of warnings!
  1. Golf gt tdi 2004 swapping instrument cluster for a gti one
    By badayuni92 in forum Golf MK5 - 2004 - 2009
    Last Post: 27-06-2015, 11:10 PM
  2. Immobiliser eeprom on instrument cluster?
    By 31satara in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-07-2014, 08:42 PM
  3. HELP!! Removed Instrument cluster, now Immobiliser not working!!
    By JCarroll in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 07-08-2012, 01:29 PM
  4. Help Immobiliser cluster problems
    By mylor in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 04-09-2011, 06:25 PM
  5. Toad Ai606 Alarm/Immobiliser with existing Golf Immobiliser
    By churd_smith in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 13-05-2007, 08:38 PM
