Thread: A4 B7 3.0 TDI Quattro Tip issue - 013128 - Control Circuit for Controller for Turbocharger 1 (J724) P3348 Electrical Malfunction - Intermittent
  1. Re: A4 B7 3.0 TDI Quattro Tip issue - 013128 - Control Circuit for Controller for Turbocharger 1 (J724) P3348 Electrical Malfunction - Intermittent
    Jan 2014
    Woking, Surrey
    Quick update..... decided that a complete refurb Turbo + Actuator assembly was not much more money than the actuator alone, no need to calibrate it then plus i get a new turbo not a 100,000 mile one which may have excess buildup on the VNT mechanism....
    Installed, went to test drive and...... no boost until like 2200rpm when it builds quickly and then pulls like a train...
    Limp mode entered with different fault code with flashing coil light.
    000565 - Boost Pressure P0235 - 001 - Regulation range not reached - MIL ON
    Have checked all hoses / vacuum lines & removed and checked the boost pressure sensor under the left hand headlight.... looked ok
    Any suggestions or anyone experienced this before?
    P0235 - 001 - Regulation Range not Reached - MIL ON
    Freeze Frame:
    Fault Status: 11110001
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 160377 km
    Time Indication: 0
    Freeze Frame:
    RPM: 2205 /min
    Torque: 163.8 Nm
    Speed: 20.2 km/h
    Absolute Pres.: 1856.4 mbar
    Absolute Pres.: 1183.2 mbar
    (no units): 108.1
    Temperature: 14.4°C
    Readiness: 0 0 0 0 0
  1. Question Fault code P2563 Turbocharger Boost Control Position Sensor Circuit: Implausible Signal
    By Audikiller in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 28-09-2018, 09:48 AM
  2. Question Fault code P2563 Turbocharger Boost Control Position Sensor Circuit: Implausible Signal
    By Audikiller in forum New Member Introductions
    Last Post: 29-08-2018, 12:21 PM
  3. 005445 - Throttle Valve Controller P1545 - 002 - Malfunction - Intermittent
    By 2fquick in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 13-03-2016, 12:23 PM
  4. Please Help Turbo controller (J724) wanted
    By wjam in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 11-06-2012, 08:03 AM
  5. Please Help Fault code P1571 Main electrical circuit relay elec malfunction.
    By barberysauto in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 28-05-2010, 07:04 PM
