Thread: Haldex filter part number please
Results 1 to 10 of 11
  1. Re: Haldex filter part number please
    135 Post(s)
    2038 Post(s)
    Yes that M10x30 bolt at the lower front left of the case (N 910 827 01) which needs an 8mm hex key to remove is the drain plug, I suppose they changed from using the tiny little M10x1 5mm Hex plug, (the same as the filler plug shown) to such a chunky design as so often we find the PQ34 Haldex drain plug thread is damaged and it is not easy to repair as the case is extremely thin at that point so you can only use an ultra short insert.
  2. Re: Haldex filter part number please
    May 2009
    Saddleworth, Yorkshire
    Thank you so much for your advice.
    Ian
  1. Fuel filter part number
    By qalaray in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-12-2013, 11:53 PM
  2. haldex oil&filter
    By lee58uk in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 24-03-2012, 07:57 PM
  3. part number of the air conditioning filter
    By CloseMix in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 12-08-2011, 09:08 AM
  4. Question 2.0 TDI oil filter part number
    By freebird69 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 25-07-2009, 10:02 AM
  5. haldex filter
    By passat 130 tdi in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-03-2008, 12:19 AM
