Thread: Throttle Body Problem
  1. Throttle Body Problem
    Sep 2018
    London UK
    Hello All,
    I've recently been experiencing a problem with my MK4 Golf that I'm struggling to get to the bottom of and am hoping for some advice.
    The issue started with the amber engine light coming on and 'hunting' when idling. First fix was an adaption of the throttle body which briefly resolved the issue. I then had the TB replace and it is still intermittently 'hunting' when idling. If I leave it to its own devices for a few minutes it revs normally and is fine for a few days.
    From reading previous posts I understand if the TB is replaced the it is necessary to reset the CPU by disconnecting the battery for 24 hours, I don't think my mechanic did this. Would doing this retrospectively and following the procedure of letting the car idle for ten minutes then taking it for an aggressive drive be a sensible approach to resolving the problem or does anyone have any other suggestions?
    Thanks a lot
  2. Re: Throttle Body Problem
    131 Post(s)
    1975 Post(s)
    Which year and engine code? It can’t be a 2L turbo what is it?
  3. Re: Throttle Body Problem
    Sep 2018
    London UK
    The mechanic has been doing all the work so I only have one code from the breakdown rescue guy 'P0130: O2 Sensor Circuit Bank 1 Sensor 1'.
    It's a 2003, as far as I know it's 2LT, that's what's stamped on the engine. I think the engine may have been replaced before I owned it as it is registered as a 1.8. I'm not at all knowledgeable about any of these things though so I could be wrong.
  1. Question Throttle body alignment problem
    By chefnikosdaniil in forum VCDS - General Questions
    Last Post: 18-07-2018, 10:08 PM
  2. Mk4 1.4 16v throttle body alignment problem
    By robbarlow in forum Golf MK4 - 1999 - 2004
    Last Post: 13-12-2016, 11:52 AM
  3. Clean throttle body and perfom Throttle Body Alignment (TBA) - big job?
    By allanmb in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 31-01-2013, 09:50 PM
  4. Another gearbox problem or throttle body?
    By a4_jim in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-08-2008, 09:51 AM
  5. Throttle body & breather problem
    By roy rovers in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-05-2008, 06:27 PM
