Thread: VW Golf GTI 2.0 inlet manifold removal
Results 1 to 8 of 8
  1. VW Golf GTI 2.0 inlet manifold removal
    Dec 2009
    Midlands
    Got a Golf 2002 2.0 GTI that needs the rocker cover gasket, spark plugs and leads that need changing. Rather than the common metal inlet manifold, it has a plastic one that I'm struggling to find any DIY how to conplete this and looking at it isn't giving me any clues either! Anyone got any tips please?
    Last edited by scrappy_doo; 16-09-2018 at 10:27 PM. Reason: 2.0 GTI Inlet Manifold
  2. Re: VW Golf GTI 2.0 inlet manifold removal
    133 Post(s)
    1989 Post(s)
    There are four different 2L 8v engines used in these cars with two designs of plastic inlet manifold, could we have your engine type code please?
  3. Re: VW Golf GTI 2.0 inlet manifold removal
    Dec 2009
    Midlands
    Believe it is AZJ
  4. Re: VW Golf GTI 2.0 inlet manifold removal
    133 Post(s)
    1989 Post(s)
    The VW instructions state rather over simplistically to "remove top part of intake manifold" and only gives this as instructions
  5. Re: VW Golf GTI 2.0 inlet manifold removal
    Dec 2009
    Midlands
    Thanks for that crasher, still as you say not the clearest job in the world! Has anyone got experience of completing the job?
  6. Re: VW Golf GTI 2.0 inlet manifold removal
    133 Post(s)
    1989 Post(s)
    Yes I have done quite a few over the years of both designs, it takes about an hour.
  7. Re: VW Golf GTI 2.0 inlet manifold removal
    Dec 2009
    Midlands
    Any tips? Doesn't seem that obvious in the diagram exactly where the fasteners are!
  8. Re: VW Golf GTI 2.0 inlet manifold removal
    Dec 2009
    Midlands
    Job completed! The main retaining bolts are at the front of the inlet manifold butn you'll need to move the air pump out the way to see them. There are 8 at the front (2 of them are 13mm nuts and the other 6 are 6mm allen bolts). Then you need to remove the throttle body (4 x 5mm allen bolts, watch out because one is longer than the rest). Then once the throttle body is out of the way you'll now be able to see a 5mm allen bolt that acts as a peg that fits inside a bushing that holds the rear of the inlet manifold (near the bulkhead) in place.
    You'll now be able to remove the inlet manifold which you'll have to angle slightly to remove it off the rear peg bushing and voila access to the spark plugs, leads and rocker cover! I've not mentioned the removal of varous electrical connections and the odd pipe here and there as it's obvious when you do it!
  1. Replies: 1
    Last Post: 15-07-2017, 10:53 AM
  2. Please Help Inlet manifold removal vw touran 2.0 tdi
    By Glode320 in forum Touran - Sharan - Caravelle
    Last Post: 15-12-2014, 07:24 PM
  3. How To 2006 2.0 tdi inlet manifold removal
    Last Post: 11-12-2014, 08:01 PM
  4. Please Help inlet manifold removal 2.3 10v engine Audi 80 Cabriolet
    By russellmyers01 in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 18-03-2012, 07:56 PM
  5. mk 5 golf inlet manifold
    By carrotts in forum Golf MK5 - 2004 - 2009
    Last Post: 15-04-2009, 01:00 PM
