Thread: Number plate lights...
  1. Number plate lights...
    Jan 2008
    Hi
    Does anyone know why my number plate lights don't work?
    I replaced both bulbs; lamp units were replaced last year and are still as new.
    I assume the fuse is either no3 or no4 (5a) and both of these are OK. I checked all the other 5a fuses for good measure.
    Is there a secret fuse I don't know about? MoT tomorrow.
    Thx
  2. Re: Number plate lights...
    Feb 2010
    Ballygobackwards UK
    I've the same problem which I haven't had time to look at yet but I've read elsewhere that:
    1 when both bulbs fail, the canbus only sends 0.5 volts to the contacts. If you replace the bulbs, it still doesn't work until the car is stopped and re-started as it only looks at the bulbs on start-up
    2 Others have spoken about the wire failing where it comes through the tailgate (avant) or bootlid (saloon).
    3 the prongs on the bulb holder which lean against the brass contacts are apparently easily accidentally bent the wrong shape so don't properly touch the brass bits.
    4 When removing the cr@p screws holding on the bulb holder, if you lose the tiny washer behind the screw, then the holder isn't tight enough against the contacts for a good connection.
    I suggest you check the voltage first if you've access to a multimeter.
    Jusr realised how old your post is. Did you solve the problem and, if so, what was the answer?
  1. Question vw polo 1.2 twist number plate lights n dashboard lights not working
    By gauchosanto in forum Polo - Derby - Lupo - Fox
    Last Post: 29-09-2017, 07:03 PM
  2. Allroad rear fog lights and number plate lights problem
    By bootie3367 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 07-08-2013, 10:08 AM
  3. LED Number plate lights
    By macmillions in forum Chat - Anything with wheels
    Last Post: 13-11-2012, 09:27 PM
  4. Led number plate lights
    By alice.puppy in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 11-10-2009, 05:16 PM
  5. led side lights and number plate lights, not working
    By adamk in forum Audi A3 - Archive Topics
    Last Post: 02-04-2008, 07:37 PM
