Thread: Struggling to start - but always does. No garage can cure it. Ideas?
Results 1 to 9 of 9
  1. Struggling to start - but always does. No garage can cure it. Ideas?
    Nov 2010
    Bolton
    Hi all,
    So - long story short. Had a Golf GT - DSG 170 - from new. Its' 56 plate
    Over the last 4 years ish it's been struggling to start. Serviced on time every time - timing belt - fuel pump - aircon - new glow plugs - new wiring loom - new battery etc etc. Basically what ever this car has needed to be done it's been done.
    Now when the car is running, it's perfect. It's starts, but needs several attempts till it fires.
    FYI - I'm rubbish with mechanics - I can put fuel in and water - thats it. Anything more than that is left to the professionsals.
    Symptoms
    1. Turn key and starter motors turns - albeit "like it's running out of power"
    2. If the lights are on (automatic lights) and the radio is on - this turning over the starter motor sounds even more "like it's running out of batteries" - really laboured.
    3. Turn lights off - radio off - try again - it still sound laboured, but less so
    4. Another interesting point - one day the windows were accidentely left open but car was locked and the alarm went off. Nothing unusal there. However the alarm was sounding for around 5 mins 10 tops - yet the sound of the alarm was like it had been running for days - indicatator blinking slowly and dimmly light - and the sound was REALLY slow and really quiet. Again "like it's running out of power"
    My next attempt is the starter motors - but to me that still doesn't explain the labour sounding/flashing of the alarm
    Unless! (And I've just thought of this now) The alternator isn't capturing all the energy from the car and charging the battery fully?? Therefore low power for starting and low power for sounding the alarm etc?
    So starter motor and alternator is working but not as effecient has it should?
    Oh I dunno - as I said - I'm poop at this sort of stuff.
    Any ideas most welcome,
    Cheers team
    Dan
    FYI - Any garage it's been to can't find anything wrong
    Passat B7 - White - Sport - 140PS BMT.
  2. Re: Struggling to start - but always does. No garage can cure it. Ideas?
    May 2017
    Wrexham, N.Wales
    Has anyone looked at the injectors, mine's in at the moment with same trouble, mechanic says injectors are all carbonated and will need replacing.
    Sent from my H8216 using Tapatalk
  3. Re: Struggling to start - but always does. No garage can cure it. Ideas?
    Nov 2010
    Bolton
    I'm told injectors are fine. Plus there was a recall on mine, prolly about, 6 years ago, to replace all injectors. I've also had the Terraclean process done on the car - which I highly recommend.
  4. Re: Struggling to start - but always does. No garage can cure it. Ideas?
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    If the battery or starter is tired it might struggle to reach minimum cranking speed which as far as I can remember is 280rpm, giving you the laboured cranking you describe.
  5. Re: Struggling to start - but always does. No garage can cure it. Ideas?
    Mar 2017
    Nottingham
    9 Post(s)
    Get a new battery on it
  6. Re: Struggling to start - but always does. No garage can cure it. Ideas?
    Nov 2010
    Bolton
    Quote Originally Posted by Ste1981 View Post
    New battery went on on Saturday
    Dan
  7. Re: Struggling to start - but always does. No garage can cure it. Ideas?
    Jul 2010
    Bradford, West Yorkshire
    6 Post(s)
    8/10 times we see these issues in the workshop its the starter motor.
    try jump starting it and see if it fires straight away
  8. Re: Struggling to start - but always does. No garage can cure it. Ideas?
    Nov 2010
    Bolton
    Quote Originally Posted by zu11y View Post
    Rough cost for replacing starter motor?
    Dan
  9. Re: Struggling to start - but always does. No garage can cure it. Ideas?
    Jul 2010
    6 Post(s)
    just checked the euro car parts site and with the current promo code it works out at £101 and a bit of change.
    Fitting cost varies by garage and location but on average should be around £40
    very easy to fit on these engine if you are a little handy at diy.
  1. Question Golf MK4 Struggling to start
    By SCOTTY91 in forum Golf MK4 - 1999 - 2004
    Last Post: 27-04-2017, 11:24 PM
  2. Question Struggling to start
    By CHEEZIE in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 13-03-2017, 08:43 PM
  3. Audi A3 1.6 TDI Struggling to start
    By Sha170 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 08-01-2015, 03:12 AM
  4. Struggling to start
    By Peteflint in forum 2.0TDi - Engine
    Last Post: 08-05-2011, 05:16 PM
  5. Help Help!!! car struggling to start
    By joe1982 in forum Bora - 1998 - 2005
    Last Post: 31-01-2010, 12:27 AM
