Thread: Golf Mk6 Faulty Boot Sensor
  1. Golf Mk6 Faulty Boot Sensor
    Sep 2018
    Leeds, UK
    Hi Everyone
    First post on here. My 2012 Golf Mk6 boot sensor has developed a fault where it thinks the boot is open when it isn't and consequently 'bings' at me constantly. Very annoying. It's also causing the alarm to keep going off.
    I've searched the forum and found info on Mk 4 and 5 Golfs, but the cable routing seems to be different on the Mk6 so I'm posting here.
    Can anyone please tell me where the sensor is located and how to fix / replace it please? Or is there simply a power cable to it I could disconnect please?
    I've attached an image of the boot with the trim removed to hopefully help identify.
    Any help would be gratefully appreciated.
    Thank you.
    Best
    Craig
  2. Re: Golf Mk6 Faulty Boot Sensor
    131 Post(s)
    1979 Post(s)
    It can be the washer jet fitting leaking onto the lock unit or a broken cable in the roof to tailgate harness on the left, the wires are all white which is very confusing.You must carefull release the conduit clamps or they will not re-seal.
  3. Re: Golf Mk6 Faulty Boot Sensor
    Sep 2018
    Leeds, UK
    Thanks for getting back to me. I've realised today the problem only seems to occur when it rains, making me suspect water is getting into the sensor but not from the washer jet fitting. Do you know where the sensor is? Is it in the lock unit?
    Thank you.
  4. Re: Golf Mk6 Faulty Boot Sensor
    131 Post(s)
    1979 Post(s)
    The flap lock sensor is in the badge handle unit and not available as a spare part, there are 4 different units depending on specification but without camera it is part number 6R0 827 469 D ULM and it costs £125.23 + VAT from TPS. I am a bit limited as to what I can do on an iPad in a Welsh cottage.....
  1. Golf TDI mk4 - Boot sensor problem!
    By Jujuman in forum Golf MK4 - 1999 - 2004
    Last Post: 20-07-2013, 11:49 PM
  2. RS6 Faulty Boot Sensor
    By RS6DMW in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 04-01-2013, 08:03 AM
  3. Are my boot struts faulty?
    By chapster in forum Passat - B5 Forum - 1997 -2005
    Last Post: 20-11-2012, 09:42 PM
  4. Mark 4 Golf Boot Sensor
    By tkeire in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 22-03-2007, 11:55 PM
  5. boot warning sensor comes on the display when the boot is shut
    By merchantmr in forum Audi A4 - Archive Topics
    Last Post: 06-02-2007, 10:04 PM
