Thread: B7 digital display mph reading in kph
Results 1 to 10 of 11
  1. B7 digital display mph reading in kph
    Hi
    I have a 2012 TDI estate with a m/f/s and the digital speed display in the box between the rev & speedo is showing the speed in Kilometres and i would like it to display in miles.
    Have tried toggling the menus to no avail so any suggestions / pointers would be much appreciated.
    Kind regards,
    Jonny
  2. Re: B7 digital display mph reading in kph
    Jan 2016
    Winchester Hants
    29 Post(s)
    This subject has been discussed over on the Skoda Forum. If I recall the answer, UK VAG vehicles do not have the function to change the MFD digital reading to mph. Because the speedo is only MPH (no Km/h numbering) if the vehicle is driven in a country where km/h are the norm, by their laws, there MUST be driver information in kM/h.
    2013 B7 Passat BlueMotion Sport Estate 2.0 TDi 177PS (CFGC), 6 speed Manual, Metallic Night Blue, Fontana alloys, Start/Stop, RNS-510 (HW H09, SW 5238 V13 maps, 8316) Nav DAB, ACC, XDS, TPM, Westfalia Tow bar, Rear View camera, Keyless Entry, Easy Open/close Electric Tailgate, Park Assist, Electric Parking Brake, DRL's, Amb light, Zebrano wood, Tinted Glass, mud flaps, 68K. Cheat emission software. Nextbase 402G iN-CAR CAM.
  3. Re: B7 digital display mph reading in kph
    Oct 2009
    Dover
    Its a simple change on VCDS to ROW from GB then it's changeable on the MFD and can display either KM/H or MPH
    Before:
    After:
  4. Re: B7 digital display mph reading in kph
    Sep 2015
    North West
    Quote Originally Posted by SimonAshley View Post
    Before:
    After:
    Hi Simon, can you elaborate a little please?
    I've got VCDS but I'm by no means expert at using it.
    I'd like to have a digital mph display but I do an annual France trip when the kph display comes in handy
    You say that by changing the settings i can then have a switchable option in the MFD?
    Could you give me a bit more info on the VCDS actions, a bit of a step by step please?
  5. Re: B7 digital display mph reading in kph
    Oct 2009
    Dover
    Hi Stu,
    The VCDS part is really easy to do
    Go to:
    17-Instruments
    Coding - 07
    Long Coding Helper
    Bit4-7 (should have a drop down box) set to 10 Rest of World (RoW)
    Close the long coding helper and select Do it!
    Select No if you get a pop up message - VCDS to try the values currently in the module
    Thats all the VCDS part
    Now on the MFD you need to do the following:
    Uncheck tick box for Alt. Speed dis
    Go to MFD Data and you should now have the option of Digit. Speed - Check this box
    From memory once this is done you can change the big digital read out under Units option on MFD from MPH to KM/h
    Let me know if you need any more help i can always go through it again on mine if it doesnt work for you.
    Good Luck
    For some reason it wont let me upload the pictures i took. Ill try again later
  6. Re: B7 digital display mph reading in kph
    Oct 2009
    Dover
    Quote Originally Posted by Stu Sheridan View Post
    Hi Stu,
    Go to:
    17-Instruments
    Coding - 07
    Long Coding Helper
    Good Luck
  7. Re: B7 digital display mph reading in kph
    Sep 2015
    North West
    Hi Stu,
    Go to:
    17-Instruments
    Coding - 07
    Long Coding Helper
    Good Luck
    Ace, thanks Simon. I'll try it later hopefully.
  8. Re: B7 digital display mph reading in kph
    Oct 2009
    Dover
    Like I say any problems let me know, more than happy to help.
    Worked on all cars I’ve done it to, Polo, Golf, Sharan, Tiguan, Passat
    Never understood why uk cars had to have a read out in kph 😳
    Also while you are in that same section of coding, I enabled instrument test (I think it’s called) does needle sweep on startup 🙈 boy racer in all of us!
  9. Re: B7 digital display mph reading in kph
    Jan 2016
    Winchester Hants
    29 Post(s)
    Never understood why uk cars had to have a read out in kph 
    Also while you are in that same section of coding, I enabled instrument test (I think it’s called) does needle sweep on startup  boy racer in all of us!
    They have to have kmh because they can be driven on la continent where cars must have a speedo reading in that countries road speed specification.
  10. Re: B7 digital display mph reading in kph
    Oct 2009
    Dover
    Quote Originally Posted by UMEL View Post
    Well obviously it's necessary for driving on the continent!
    The point was more why do all of them come locked to show kmh when most miles in a UK car is in mph and you can't select mph without the use of VCDS and if you ask VW dealer they say it's not possible
    Once changed to Rest of World spec with VCDS you get the choice of mph or kmh.
    UK cars don't come with headlamps conforming to driving on the right hand side it's a choice on xenon equipped cars to change between the two so why don't they do it with the Speedo!
    Sent from my SM-G955F using Tapatalk
  1. Question RNS 510 digital clock display
    By UMEL in forum In Car Entertainment
    Last Post: 06-02-2016, 10:37 AM
  2. digital display
    By abby1 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 12-08-2013, 12:31 PM
  3. C6 2.0tdi s line 170 digital speed reading
    By nigedvd in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 28-05-2012, 07:20 PM
  4. digital display on speedo
    By bbuk2004 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 22-01-2012, 11:21 PM
  5. Digital display on MK4 TDI 130
    By freewheeler1968 in forum Golf MK4 - 1999 - 2004
    Last Post: 20-08-2010, 01:35 PM
