Thread: Cold start issue on pd100
  1. Cold start issue on pd100
    Aug 2018
    Gloucester
    When starting from cold the car really struggles have to crank it a few time before it fires. The flow plug light doesn't stay in for very long. Just replaced the collar sensor and is still doing it. Have u plugged the sensors the glow plug light stays in for longer and then will fire straight away. Is there something I'm Missing
  2. Re: Cold start issue on pd100
    Jul 2015
    Staffs
    46 Post(s)
    For a start we need you car model so i can move it to the correct section.
    Scanned for codes?
    Could be air leak in the fuel system rather than a glowplug issue.
    Ian
    A4 B6 Avant Nogaro Blue
  3. Re: Cold start issue on pd100
    134 Post(s)
    2004 Post(s)
    If it is a 2003 model it could have glow plug monitoring and I would suspect you have a couple of failed glow plugs.
  1. Question 2.8 30v v6 cold start issue plus other symptoms
    By Quattrotech2016 in forum A8 - S8 - V8
    Last Post: 29-04-2016, 08:48 AM
  2. Passat cold start issue how to fix
    By davepassat in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 27-07-2014, 07:30 PM
  3. Cold Start Issue
    By mike_low3 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-11-2008, 02:58 PM
  4. cold start issue
    By tattooedferret in forum 80 - 90
    Last Post: 27-09-2008, 12:45 PM
  5. K-Jet Cold start issue
    By Dee-GTI in forum Golf MK2 - 1984 - 1992
    Last Post: 17-04-2008, 05:52 PM
