Thread: Help! Hub and spacer issue!?
Results 1 to 10 of 14
  1. Help! Hub and spacer issue!?
    Jan 2013
    Scotland
    11 Post(s)
    I have aftermarket wheels on my car, supplied and fitted by a company in Scotland. Just had my car back from audi for front brake replacement and they found this.
    50555 | AudiCam
    Obviously I'm going to take it back to wheel shop, but how would you resolve this?
    Griogair
    Audi A6 3.0 BiTDI Black Edition
  2. Re: Help! Hub and spacer issue!?
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    That looks like a universal fit type spacer that would cover a range of PCD's with a centre bore way to big for your hub spigot, it will be relying on the bolts to centralise it, must be a total PITA to mount the wheels! - see if you can find a suitable spacer size specific to your hub spigot, PCD and thickness, somewhere like here:
    https://www.performancealloys.com/ac...el-spacers?p=3
    Bolt length needs checking as well, if the locking bolt is only engaged by a few threads it will either come loose or strip your hub threads after a few tightenings. If the wheel is not mounting onto the hub spigot properly you'll be relying on the bolt tapers to centralise the wheel as the bolts are tightened. I'd also make sure that your new wheels are compatible with the conical wheel bolts being used and do not require ball or radius seat type bolts.
    Are you sure the supplier is competent to be fitting wheels ?
  3. Re: Help! Hub and spacer issue!?
    Aug 2009
    Usa
    6 Post(s)
    98 Post(s)
    That is really poor! Surprised you have not noticed any vibration. I would get them off asap and either use the oem wheels in the mean time until you get a proper set of 66.5 c/b spacers and correct length including the locking bolt. Again make sure the bolts match the hole ie taper or radius.
    0 2 0
  4. Re: Help! Hub and spacer issue!?
    Jan 2013
    Scotland
    11 Post(s)
    I took one front wheel off tonight. I got 2.5 turns on the lock nut! Looks like about 9 on the other 4. As far as I can see they have used a 5mm spacer to get past the caliper. It has left 9mm of hub bore to locate the wheel. Trouble is, I've got approx 5mm chamfered face on my rim, so I've only got 4mm of hub bore available to seat my rim. That's surely not acceptable? You can see eye rusty residue on the rim.
    Guys, I'd really appreciate if someone could give me an exact link to a specific hubcentric spacer I could buy.
    Uploaded selection of pics I took this afternoon FYI.
  5. Re: Help! Hub and spacer issue!?
    Aug 2009
    Usa
    6 Post(s)
    98 Post(s)
    You need a 5mm spacer to clear the calipers; but no one makes a 5mm 'hubcentric' spacer! hence why you have probably ended up with a universal spacer. The bolts are the correct length: 27+5mm= 32mm
    Ideall see if you can get away with a 10mm spacer on your set up without having the tyres protruding outside the arches. If so then you can get some hubcentric spacers such as H&R, Eibach or Bimecc etc.
  6. Re: Help! Hub and spacer issue!?
    Jan 2013
    Scotland
    11 Post(s)
    Unfortunately the locking bolt is definitely not the right size. I didn't post a pic, but you can see the difference in the video. Much smaller and only gets 2 and a half turns.
    Jeez, why don't you get a 5mm hubcentric?! That's not what I want to hear.
  7. Re: Help! Hub and spacer issue!?
    Nov 2010
    104 Post(s)
    have a look on the link I posted in #2 , I'm seeing the sort of spacers you need there by searching for A6 C7, bringing up spacers at 5x112pcd centre bore of 66.45mm, such as these with centering collar or spigot https://www.performancealloys.com/ei...r-system-2-8mm. drop them a line if in doubt. They do locking bolts in various lengths as well.
  8. Re: Help! Hub and spacer issue!?
    Jan 2013
    Scotland
    11 Post(s)
    Quote Originally Posted by Rob69 View Post
    Thanks Rob. I put my car details in, and I searched for 5mm spacer. It tells me this H&R spacer will fit, but the PCD and centre bore specified here aren't what I need. So I'm a little confused
  9. Re: Help! Hub and spacer issue!?
    Jul 2016
    Chestfield kent
    81 Post(s)
    Hi. Looking at this from the other end of the issue, if you have a 5mm spacer to clear the calliper then, have you considered removing material from the rim. It would need to be done correctly. but if it were to be only a couple of mill over a small part of the inner rim it may be possible. Again I would advise having it done by an engineering firm. That way it would put less stress on the hub and bolts. Or have a firm make you a set of spacers and bolts to do the job properly.
  10. Re: Help! Hub and spacer issue!?
    Nov 2010
    104 Post(s)
    Quote Originally Posted by gdallas View Post
    I think you'd best contact that company or another wheel specialist to ensure you get what you need - I sent you that link as an example of what's out there, I don't want to specify a particular spacer set for you and then you find it is no use for whatever reason !!
    your original supplier has been pretty shoddy though, especially fitting a wheel bolt with two threads engaged, they were lucky to get the required torque without stripping the bolt and hub - if it was even torqued correctly.
  1. wheel spacer help
    By roy2001 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-01-2010, 12:37 AM
  2. Spacer Question
    By redducati in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 17-02-2009, 10:05 PM
  3. Turbo Spacer
    By kc1010 in forum Audi A3 - Archive Topics
    Last Post: 02-11-2008, 09:49 PM
  4. Question Tyres / Spacer Help
    By pjjohnst in forum Chat - Anything with wheels
    Last Post: 30-08-2008, 09:05 AM
  5. Spacer advise please....
    By JXP in forum Archive posts
    Last Post: 23-01-2008, 02:15 PM
