Thread: Violent engine shake, hot start
  1. Violent engine shake, hot start
    Aug 2016
    newcastle upon geordie land UK
    2005 mk5 Golf Plus, 1.9 TDI PD90, BRU
    92k on the car
    Hi all, I know there are threads on this but they all seem very dated, I'm having the issue myself now so id like to go through what I've done (so far) and what I plan to do next, so...... this all started after a DMF and clutch change I was supplied the wrong units, the parts I was given first were sachs numbers
    336 44 0720 - flywheel
    641441939 - clutch kit
    The replacement parts supplied after euro parts realised they had gave me the wrong clutch are
    641 44 2880 - clutch kit
    All is now good with the clutch and flywheel but the hot start shake still persists ! So I have went through the following
    Clutch & flywheel twice,
    Fuel, air, oil filter and oil,
    EGR valve
    Anti-shudder valve,
    Timing with new belt kit and w/pump,
    Alternator and over running pulley
    Dog bone mount insert,
    Low and behold !! It is still there so after lots of reading and taking the car to a VW specialist my next steps are to replace the battery with a duracell 72ah, 720 cold crank battery and also a new Bosch starter motor, it is mine and the VW specialist opinion that the starter motor is drawing all the power from the battery leaving nothing to fire the injectors causing a start/stall type situation coupled with the starter not disengaging fast enough, this is resulting in the horrible violent shudder
    I'm also now having to replace the transmission and engine top mounts as they have been literally shook to bits
    Apart from this a remap has been suggested but this is usually for the hot start issue where the car won't crank over or takes a long time to crank over when hot, I'm not having these symptoms at all
    Any advice is appreciated as after I've installed the new battery and starter I have no more options to get this resolved if it still persists I've ploughed too much money into the car to give up now
    Thanks,
    Mick
    Sent from my SM-G950F using Tapatalk
  2. Re: Violent engine shake, hot start
    Aug 2016
    Any help at all is appreciated
  3. Re: Violent engine shake, hot start
    Mar 2017
    Nottingham
    9 Post(s)
    Have a look at your torsion value mine use to shake and feel like a slight miss fire until I had a new timing belt, and tweaked the torsion value
  4. Re: Violent engine shake, hot start
    Aug 2016
    Quote Originally Posted by Ste1981 View Post
    Does this need done through vcds? Thanks
  5. Re: Violent engine shake, hot start
    Aug 2016
    Well the verdict is in......
    Put new battery on - no difference at all,
    Put old battery back on and fitted new starter - again, no difference at all !!
    Put new battery back on with new starter - hey Presto !! Hot start shake has disappeared, ive ran it 20 miles and tested it over and over and it's 100% cured it,
    Thanks for everyone's advice on this
  1. Solved 2007 2.0TDI Multitronic - Engine Shake/Judder on Hot Start
    By jeboa in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 24-05-2023, 01:14 PM
  2. Violent engine shaking on hot start after DMF change
    By mure in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 16-05-2017, 11:43 AM
  3. Question 2007 2.0TDI BRE Multitronic - Engine Shake/Judder on Hot Start
    By Scotty0159 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 26-04-2014, 09:20 AM
  4. Please Help 04 TDI S 1.9 105 bhp - Violent hot start
    By Drifterwanab in forum Golf MK5 - 2004 - 2009
    Last Post: 21-10-2012, 11:08 PM
  5. Please Help Engine violent shake on hot start (2.0tdi)
    By alanscottgraham in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 11-09-2012, 11:09 PM
