Thread: Fule filler overflow pipe
Results 1 to 10 of 11
  1. Fule filler overflow pipe
    Jul 2016
    Chestfield kent
    81 Post(s)
    Hi. Anybody know where the filler overflow pipe goes to. Just toped up Adblue and spilt a little but it did not drain away. So did the wire down the pipe trick, hoping to unblock it but it came to a dead stop at about 3ft !!! So I am assuming the blockage is at the end and the wire is not stiff enough to move it, but where is the end ! Have looked all around the arch area, but unable to locate it. Anybody know where it is !!! Thanks in advance...
  2. Re: Fule filler overflow pipe
    Feb 2013
    Finland
    13 Post(s)
    Not sure if FL has the same:
  3. Re: Fule filler overflow pipe
    Jul 2016
    Chestfield kent
    81 Post(s)
    Thanks. Have had a look there is a clip point but no pipe. You could be correct as had the flap inner replaced several weeks ago due to lock failing, they may not have located it correctly, if so ??????? Or FL may be in a different location. Thanks anyway.
  4. Re: Fule filler overflow pipe
    Feb 2013
    Finland
    13 Post(s)
    It might be so that during removal of the assembly the pipe has been drawn off from its proper position either from top end or bottom end. Anyway, the excess fluid shall go somewhere in to the bumper area behind the rear wheel. If you pour water into the pot behind the flap, look where it goes.
  5. Re: Fule filler overflow pipe
    Jul 2016
    Chestfield kent
    81 Post(s)
    That's the problem, it don't go nowhere just sits there contemplating life. Encouraged it to go with the wire down the pipe but it was happy to just sit there. Even after 10 min no drips anyware if I can locate the end I can let it flow, hopefully... Thanks anyway.
  6. Re: Fule filler overflow pipe
    Feb 2013
    Finland
    13 Post(s)
    Hopefully not going to spare wheel compartment...
  7. Re: Fule filler overflow pipe
    Jul 2010
    Monmouth, Wales
    7 Post(s)
    If you look at the picture posted previously, it says the drain pipe is under the wheel arch liner. I would think that you need to remove the liner & reroute the pipe correctly.
  8. Re: Fule filler overflow pipe
    Dec 2010
    CD UK
    6 Post(s)
    When my fuel flap solenoid was changed unnecessarily, the overflow pipe was left hanging a couple of inches below the bumper. I was about 200 miles away from the dealer who couldn't explain over the phone how it should fit. I took a look, and guessed that it was held in by the moulded "chicanes" and it has since stayed put. But that's on an allroad. Seeing the image I can see that it's correct, but without having done it myself I wouldn't necessarily have worked that out from the image alone (which could do with a note or a zoom-in).
  9. Re: Fule filler overflow pipe
    Feb 2013
    Finland
    13 Post(s)
    Checked the document and there is no note(s) associated with this drawing or assembly.
  10. Re: Fule filler overflow pipe
    Jul 2016
    Chestfield kent
    81 Post(s)
    Resolved... thanks to" diecastsink" for the info, that is the correct location on a FL. Discovered today that the "numpty" who did the work under warranty did not bother to ensure that it was fitted correctly. The pipe is about 3ft long and runs between the arch and the liner, "numpty" had just pushed the pipe down the rear of the arch but not located it to the side of the bumper, it had looped in between the arch and liner, the end had gone back up and ended up higher than the end in the filler moulding !!! Hence not draining... Will be Emailing the Dealer.... So if you have this done make sure it drains before leaving the workshop.... Thanks to all.
  1. Scirocco mk11 fuel tank filler pipe
    By nzprelude in forum Scirocco - Corrado
    Last Post: 06-05-2011, 10:36 PM
  2. fuel filler pipe
    By kbgc in forum Golf MK1 - 1974 -1984
    Last Post: 27-05-2009, 12:13 AM
  3. fuel filler pipe
    By kbgc in forum Reviews & Recommendations of Dealers & Independant Garages
    Last Post: 15-09-2008, 10:54 PM
  4. fuel filler pipe
    By kbgc in forum New Member Introductions
    Last Post: 13-09-2008, 12:19 PM
  5. newb looking for fuel filler pipe
    By libs45 in forum New Member Introductions
    Last Post: 13-09-2008, 12:15 PM
