Thread: a4 b6 front arb?
Results 1 to 10 of 11
  1. a4 b6 front arb?
    Sep 2007
    antrim, n ireland
    DILLEMA.....my creaking noise in the front is now accompanied by a clunking over cobbled roads, was away couple days therre in south of ireland and noticed this annoying sound!!
    i think its the front arb, i dont know wether to change the whole bar and bushes etc, or just the bushes, as the original audi bar iirc is smaller in diameter therefore the newer type replacement bush will be slack, which i dont want my mechanic to realise when i book the car in with him to get these fitted, as it means paying him for his time twice, to get it booked in again to fit complete bar and bush set, i want the s4 bar which seams to be exactly the same going by the part numbers and prices quoted by vag parts,
    has anyone got any info to add on these , how i can tell the difference in the original arb fitted as standard and the new replacement also standard A4/S4 arb dimensions, is the replacement bar bigger or just the section that the bush covers, therefore i need to take the bush off to measure its diameter,
    I am aware that the original bar had plastic collar between bush and bar, this splits and creaks, so the replacement has no plastic collar, whats the craic with the new bushes though, sizes etc
  2. Re: a4 b6 front arb?
    133 Post(s)
    1986 Post(s)
    The ARB will be the problem, not the bushes so replace the ARB.
  3. Re: a4 b6 front arb?
    Sep 2007
    antrim, n ireland
    been in contact with vagparts, they have the arb,s in stock, but before i buy, is the s4 the same as the a4 , will the b6 s4 arb fit my b6 a4? without any mods, is it exact fit?
  4. Re: a4 b6 front arb?
    133 Post(s)
    1986 Post(s)
    It all varies; even the replacements may not be the same as the original.
  5. Re: a4 b6 front arb?
    Oct 2006
    I needed a bolt for ARB as mine dropped out after some work on the car. The parts diagram at Audi for my car was a completely different ARB. Mine has a bolt which screws into the end of the bar rather than through the bar with nut and bolt as per the Audi diagram for my car.Also the ARB on mine is a thick bugger so not sure if this is the 'later' one you are refering too. I'd guess from memory at the bar being about 25-30mm thick which is quite thick for a ARB!!
    If you have knocking noise and you're sure its from the ARB I would change the bushes as the bar is just a bar and doesn't wear. I would also check ball joints on the suspension arms.
    Mine is a 2003 1.9TDI 130.
    A4 Avant 1.9 TDi160 for when the weather is on the damp side - Sold after 9yrs. Now A5 3.0TDI Q Sport Coupe (310bhp/480ft/lbs - Yamaha R6 for when its dry and want some 'High octane Petrol' fun.
  6. Re: a4 b6 front arb?
    Sep 2007
    antrim, n ireland
    all suspension bushes etc 100%, its clunking now, was creaking before on drivers side, now both sides are doing it if i listen carefully, so its both bushes gone, but i dont want to order bushes and end up they are too big for my original bar, then have to re order a arb, i thought at £100 all in for s4 bar, bushes and bolts etc delivered to n ireland was not that bad, so just replace the lot!! or shud i get it measured and then order bushes to suit
  7. Re: a4 b6 front arb?
    Sep 2007
    antrim, n ireland
    replaced the front arb...i put the s4 one on(thicker) , got my car back today. and it is still creaking, i am now very ****** off, ...i replaced bushes, screws etc the lot, the type i had on my 03 tdi sport, was the bolt screwing in to the end, the one that i got taken off was identical, which i cuould not of measured before hand as i had no way of getting under it, lowered 55mm/ , has anyone got any idea of what this could be, ps crasher i was listening to you regarding the arb, so i replaced it as my mechanic could not find the fault, now i am out couple hundred quid and its exactly the same!!!!
  8. Re: a4 b6 front arb?
    133 Post(s)
    1986 Post(s)
    Eek! Did you replace the ARB end links? It is evil to try and diagnose a noise by text.
  9. Re: a4 b6 front arb?
    Sep 2007
    antrim, n ireland
    no, but today i sprayed wd40 in around both droplinks, and the creaking has gone away, but i now have a strange clunk when i go over a speed bump, sounds like a spring dropping back into its seat or someting similar, while under the car i noticed that all control arms etc where fresh looking, and all bushes had no wear, the creaking droplinks will probably reappear within a few weeks, if so i will take them off and replace or coat them with good grease. as there is no play in them, car is running sweet now, very quiet and fault free, apart from the strange clunk that has appeared just after jacking up the drivers side which is the opposite side from the problem i was first having... i have the car lowered 55mm eibach sport kit, standard sport dampers, have a feeling the spring could do with being cable tied in place, so as there will be no movement when the leg drops over big speed humps!!
  10. Re: a4 b6 front arb?
    133 Post(s)
    1986 Post(s)
    You need 40-mm shortened dampers.
  1. rs6 front grill
    By sbt in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 01-06-2007, 04:37 PM
  2. mk4 golf front clunk on full lock then front rattle over bumps
    By jwexqm in forum Golf MK4 - 1999 - 2004
    Last Post: 30-05-2007, 11:04 PM
  3. Front
    By T_C in forum Passat - Archive Topics
    Last Post: 18-12-2006, 10:33 AM
  4. Front end noise
    By Gaz the Cab in forum Passat - Archive Topics
    Last Post: 29-11-2006, 04:41 PM
  5. Front End
    By Marc97 in forum 80 - 90
    Last Post: 23-11-2006, 11:09 PM
