Thread: Mk4 GT TDI 130 PD - No Boost
Hybrid View
  1. Mk4 GT TDI 130 PD - No Boost
    Aug 2018
    Northern Ireland
    Okay so this is the first time in a lot of years I’ve had to ask for help, but I’m baffled here, whether it’s too many lates nights at the garage and not enough sleep I’m not sure, but here goes...
    I have a golf in here at the moment that had a leaky turbo, so it was replaced, was absolutely fine for a few days, was pulling better than the original turbo, then one night it stopped boosting, ran like a 90 bhp, left it for the night but the next morning it was fine, later again that night she done the same thing again, but this time didn’t recover.
    Took the intercooler and all the pipes off, sprayed and filled the intercooler with brake cleaner, let it sit for a while, then blew it out, let the egr soak in petrol overnight and cleaned all the pipes, put it all back together and still the same, put the old turbo back in to see if it’d boost, nothing, won’t boost at all on a turbo I know is working.
    Vag com is typically showing “charge pressure control - negative deviation” but that’s it, not other faults, other than the air flow position sensor for the ac but that’s irrelevant.
    I’m at a major loss as there are no boost leaks... anyone got any advice ? Feel free to point out the obvious too... thanks
  2. Re: Mk4 GT TDI 130 PD - No Boost
    135 Post(s)
    2039 Post(s)
    But that code isn’t typical, 17965 POSITIVE deviation is the normal one, 17964 NEGATIVE deviation is a huge clue. Do you own a Mitty Vac?
  1. Please Help constant full boost!!! boost leak? MAP sensor?
    By boratdi150 in forum Bora - 1998 - 2005
    Last Post: 21-11-2017, 09:56 PM
  2. Strange boost issue (base boost sometimes)
    By fivepointnine in forum Leon
    Last Post: 10-04-2017, 11:48 AM
  3. Replies: 1
    Last Post: 06-06-2014, 09:50 AM
  4. Please Help 2003 S3 Boost Problem, little or no boost.
    By Jonaman in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 21-05-2013, 04:41 PM
  5. Please Help Stuttering on boost, knocking when passing boost?? HELP please!!
    By JimboTD5 in forum Golf MK4 - 1999 - 2004
    Last Post: 07-06-2011, 05:24 PM
