Thread: Air Con Problem
Results 1 to 10 of 20
  1. Air Con Problem
    Dec 2014
    Blackheath UK
    We Have a 2004 54 Audi A4 the problem we are having is the Aircon is blowing cool air but not cold air
    we have checked the motor and the condenser they are all fine
    The pipes under the bonnet is freezing and that seems to be fine
    Could it be the evaporator outflow temperature sensor
    can you confirm this for us please
    any help would be great please.
    Matt Nicoll
  2. Re: Air Con Problem
    Feb 2004
    Yorkshire
    49 Post(s)
    @Crasher can you help with this issue
    Stuart l VWAudi Forum
    VW Audi Forum - Founder
    Ways to support the website
  3. Re: Air Con Problem
    Apr 2018
    N.Ireland
    9 Post(s)
    G65 Sensor, i've just had to replace mine aswell, it was full of salt.
  4. Re: Air Con Problem
    Dec 2014
    Blackheath UK
    Hi Can you tell us where the G65 Sensor is please and how to replace it please
  5. Re: Air Con Problem
    Apr 2018
    N.Ireland
    9 Post(s)
    It is on the sid of your air con radiator, open the bonnet and look down beside the passenger side headlight. You will need to remove it and check the code, mine was 8Z0959126 but also dont buy the wrong sensor as i did by just matching the code somehow online it also seems to refer to a newer sensor which doesn't fit. i bought this one the second time around Air Con Pressure Switch 6ZL351028-401 Hella AC Conditioning 3R0959126 8E0959126 4045621463595 | eBay
  6. Re: Air Con Problem
    Dec 2014
    Blackheath UK
    Do we have to drain the air con fluid to remove this and do we need to remove the bumber as well or can we just get to this via the Bonnet
    Please let us know asap please
    Matt
  7. Re: Air Con Problem
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    there is a schrader valve under this sensor that should seal off as the sensor is removed, bumper and maybe headlight need to be removed.
  8. Re: Air Con Problem
    Jan 2009
    Birmingham
    36 Post(s)
    Removing and installing high-pressure sender -G65-
    Unplug connector -B-.
    Remove high-pressure sender -G65--C-, tightening torque: 5 Nm.
    Replace O-ring -A- (10.8 mm; 1.8 mm) → Chapter.
    Note
    t The cooling output cannot be checked with the high-pressure sender -G65- removed; the operating and display unit, Climatronic control unit -J255- does not switch on the compressor.
    t The refrigerant circuit remains closed, “connection with valve”.
    t Checking operation of high-pressure sender -G65- and signal supplied → Chapter and→ Chapter.
  9. Re: Air Con Problem
    Dec 2014
    Blackheath UK
    Crasher Have you got any ideas please
  10. Re: Air Con Problem
    May 2008
    Newbury
    Most likely is either low on gas (even if you get a cold pipe, that may mean it is evaporating there rather than in the evaporator unit) or a failed sensor.
    Vagcom/VCDS will diagnose a sensor fault (check the pressure reported by the sensor), lack of gas is a job for an aircon specialist. If you don't have the kit to handle the gasses then there isn't much you can do other than the sensor anyway as it will need the gas to be removed before breaking into the system and replaced afterwards for any of the other fixes.
  1. Please Help 2001 1.9TDI power problem, freezing trip computer and starting problem
    By chapster in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-10-2014, 12:44 PM
  2. Sat Nav problem? Or user problem? Can't select postcode entry.
    By rafletcher in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 04-09-2012, 10:41 AM
  3. Puzzling coolant temperature problem (not just a sender problem)
    By bartonthesparta in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-12-2009, 06:58 PM
  4. Exhaust emissions/temperature gauge problem/starting problem
    By joncope in forum Polo - Derby - Lupo - Fox
    Last Post: 06-07-2009, 04:31 PM
  5. Stuck door problem, central locking problem & no alarm
    By andyaudia4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-11-2008, 05:57 PM
