Thread: Neutral position sensor
Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
  1. Re: Neutral position sensor
    Jun 2021
    lincoln
    I've just gone and bought a Passat B7 with the 1.6TDI engine and have this issue, was it ever answered @decker39
    Many thanks
    Dan
  2. Re: Neutral position sensor
    Nov 2013
    Stoke on Trent
    Quote Originally Posted by smith2001uk View Post
    Many thanks
    Dan
    No mate
  3. Re: Neutral position sensor
    Jun 2021
    lincoln
    ah bugger, I've found videos of this sensor being replaced but never for the TDI 1.6 CAYC engine. Did you ever have any luck with rectifying your issue with it?
    thanks for getting back to me regarding this btw
    Dan
  4. Re: Neutral position sensor
    Nov 2013
    Stoke on Trent
    Dan
    No luck unfortunately, just lived with it in the end
  5. Re: Neutral position sensor
    1841 Post(s)
    It is on the side of the gearbox behind the starter but has to be calibrated.
  6. Re: Neutral position sensor
    Jun 2021
    lincoln
    Thank you very much Crasher. Thats totally my luck, a special sensor that costs more than just fitting. Guess i'll be living with it too.
  7. Re: Neutral position sensor
    #17
    1841 Post(s)
    If my stop/start system went faulty I would celebrate with another vodka… but then again after two that would be not a good idea on a school night…
  8. Re: Neutral position sensor
    #18
    Jun 2021
    lincoln
    I'll just crack on with my other issues, glow plug 3 U/S, leak on injector 4, think there is a very slow leak from the coolant system and the air con gets worse the hotter it gets or sometimes just works. I tell ya i can pick the cars!
  9. Re: Neutral position sensor
    #19
    Dec 2023
    Aberdeen
    Anyone fix this fault
  10. Re: Neutral position sensor
    #20
    Dec 2023
    Aberdeen
    Got a a3 2012 2.0 TDI manual
    Coil light started flashing
    Start stop error on dash
    Takes longer to start also got
    Neutral position sensor electrical error
    And neutral position sensor short circuit to ground
  1. Camshaft position sensor / sender (G40 Hall sensor) replacement Audi A6 2.0 BRE
    By Strath44 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 19-05-2016, 02:26 PM
  2. Replies: 3
    Last Post: 26-05-2011, 12:07 PM
  3. Replies: 8
    Last Post: 07-02-2009, 11:21 PM
  4. maf sensor position??? Help
    By chrissgoduk1985 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 20-04-2008, 11:03 PM
  5. Cam Position Sensor
    By zenmaster in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 24-02-2007, 10:57 AM
