Thread: Diagnostic Socket?
  1. Question Diagnostic Socket?
    Jun 2018
    Worthing West Sussex UK
    Dear All, can anybody help? I have a Passat 1989 with a PB engine. Does it support a diagnostic option? If yes, where do I find the socket, and will it be of the two plug type or an OBD type?
    Your help either confirming this option isn't available on this year, or to find the output socket, will be much appreciated.
    Kind regards,
    davidsds.
  2. Re: Diagnostic Socket?
    Dec 2014
    Bedford
    42 Post(s)
    2 plug socket, its flash codes, if i remember correctly its near the dash cluster you pull off a plastic cover and its there.
  3. Re: Diagnostic Socket?
    2009 Post(s)
    No the PB has no diagnostic abilities. On the type 31 the diagnostic sockets would be under the gear lever boot holding trim which just lifts up. You will likely find a small black two pin plug in there which most type 31’s had as if they had the PF, 9A, 2E or AAA engine which did have diagnostics they had another white plug and if they had ABS that also had blue diagnostics plug with one wire. To read these systems you need the so called OBDII to VAG 2x2 adapter but VCDS cannot read some of the very early systems so I still have my old system from the 90’s which will read flash codes and very early OBD systems.
  4. Re: Diagnostic Socket?
    Jun 2018
    Thank you, I feared that to be the case!
    Regards, davidsds.
  5. Re: Diagnostic Socket?
    Jun 2018
    However, is there any way of extracting any recorded DTCs from the ECU of a Passat PB engine of this age?
  6. Re: Diagnostic Socket?
    2009 Post(s)
    No, they have no fault code abilities.
  1. Diagnostic socket
    By audipersempre in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 25-08-2010, 12:53 PM
  2. Diagnostic Socket?
    By rsymes2k in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 07-02-2009, 03:05 PM
  3. Question Diagnostic socket
    By vector74 in forum 80 - 90
    Last Post: 15-05-2008, 08:41 AM
  4. diagnostic socket
    By andy wood in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 25-02-2008, 05:59 PM
  5. Diagnostic Socket - Where is it??
    By marleyp in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 21-06-2007, 10:04 PM
