Thread: Q7 4M Rear View Camera - Retrofit
Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
  1. Re: Q7 4M Rear View Camera - Retrofit
    #11
    Jan 2022
    Hi, thanks for this insight. I'm looking to do the same but haven't found a reasonable guide on the boot trim removal/cable laying along with connection to the relevant box in MMI. Is there a guide you would recommend on this please? Thank you.
  2. Re: Q7 4M Rear View Camera - Retrofit
    #12
    Jun 2022
    Krakow
    Rear camera coding - Is it ok?
    Module 19 Gateway
    • Select Installation List
    • Check 6C Rear View Camera
    • Save
    Module 09 Central Electrics
    • Select Coding
    • Go to Byte 35 and check Bit 4
    • Exit and Do it!
    Module 5F Multimedia
    • Select Adaptation
    • Search for VPS
    • Car_Funktion_List_BAP_Gen2_VPS set the new value activated and press Do it!
    • Car_Funktion_List_BAP_Gen2_VPS_msg_bus set the new value Terminal 15 and press Do it!
  3. Re: Q7 4M Rear View Camera - Retrofit
    #13
    Apr 2014
    SW London / Surrey
    10 Post(s)
    168 Post(s)
    Whatever that bit does may somewhere else in different control module versions, so you should make sure it looks like the right thing to be setting rather than doing it blindly:
    I can't comment on the other parts.
  4. Re: Q7 4M Rear View Camera - Retrofit
    #14
    Oct 2013
    Coventry UK
    Hi Andy, where did you tap into for CAN wires? I believe this camera uses extended CAN system for communication?
  5. Re: Q7 4M Rear View Camera - Retrofit
    #15
    Sep 2022
    The easiest place I found is at the connector for the adblue control module behind the right rear luggage compartment side trim. Check out the service manual for details and wiring diagram.
    If you have some of the more advanced driver assistance modules the extended canbus wire might be present behind the left side trim by the fusebox, but mine didn't.
  6. Re: Q7 4M Rear View Camera - Retrofit
    #16
    Oct 2013
    Coventry UK
    Hi mate, yeah I did see that in Erwin last night, J880 Control unit for reducing agent metering system seems like has extended CAN also, much easier than tapping into GW under seat thanks for confirming.
  1. C7 rear view camera retrofit
    By buddyboy in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 10-12-2020, 12:25 PM
  2. Replies: 0
    Last Post: 07-05-2017, 07:25 PM
  3. OEM Rear view camera retrofit
    By Dogjen in forum Passat - B8 Forum - 2015 -
    Last Post: 21-09-2016, 07:11 PM
  4. Overhead / top view camera retrofit
    By Q7quattro in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 22-12-2015, 08:51 AM
  5. Retrofit rear view camera - VW Sharan 7N 2013 model
    By Kit James in forum Retrofits
    Last Post: 04-03-2015, 03:20 PM
