Thread: Q7 4M Rear View Camera - Retrofit
Results 1 to 10 of 22
  1. Post Q7 4M Rear View Camera - Retrofit
    Mar 2010
    37 Post(s)
    228 Post(s)
    All,
    A short while ago I completed a second retrofit for fellow forum member Steve on his lovely Q7 S-Line in Orca Black. (First was Drivers Side Seat Memory Buttons).
    This was a Rear View Camera retrofit as the car only had the parking sensors as standard and involved swapping out the rear door handle for a new handle that contains the camera, relevant connections to the MMI Unit, Power and Coding.
    Install took about 3 hours to complete.
    Lovely Car:
    New vs Old Rear Door Handle:
    New Rear Handle Installed and cabled in:
    Wire Routing:
    Removal of MMI Unit and Glove box and wiring into the relevant MMI Connectors:
    Finished Camera:
    Andy
    0 2 0
  2. Re: Q7 4M Rear View Camera - Retrofit
    Apr 2016
    London, UK
    Quote Originally Posted by andyhud007 View Post
    All,
    Lovely Car:
    Wire Routing:
    Finished Camera:
    Andy
    Great work Andy, are you able to share ball park costs for this retrofit? Thanks
  3. Re: Q7 4M Rear View Camera - Retrofit
    Mar 2010
    37 Post(s)
    228 Post(s)
    PM'd you mate.
    Andy
  4. Re: Q7 4M Rear View Camera - Retrofit
    Nov 2017
    Halifax
    Hi Andy well happy with both job's you have done on my car a bot late on the reply but haven't been on the forum for a bit
    Steve
  5. Re: Q7 4M Rear View Camera - Retrofit
    Aug 2008
    i have just finished fitting the camera to my 2016 Q7 4M but i am unable to find any info on coding, would anybody be able to help please
  6. Re: Q7 4M Rear View Camera - Retrofit
    Mar 2010
    37 Post(s)
    228 Post(s)
    Quote Originally Posted by deutsch View Post
    PM me and we can chat
  7. Re: Q7 4M Rear View Camera - Retrofit
    Jul 2010
    United Kingdom. Northampton
    6 Post(s)
    Andy,
    Are we full 'plug and play' albeit with a few bits of trim to remove ?
    Thanks muchly, Iain
  8. Re: Q7 4M Rear View Camera - Retrofit
    Mar 2010
    37 Post(s)
    228 Post(s)
    Quote Originally Posted by Iain Drage View Post
    Andy,
    Thanks muchly, Iain
    Nearly Iain. Little bit of wiring and a little bit of coding but generally.. Yes
  9. Re: Q7 4M Rear View Camera - Retrofit
    Jan 2022
    Hi, thanks for this insight. I'm looking to do the same but haven't found a reasonable guide on the boot trim removal/cable laying along with connection to the relevant box in MMI. Is there a guide you would recommend on this please? Thank you.
  10. Re: Q7 4M Rear View Camera - Retrofit
    Jun 2022
    Krakow
    Rear camera coding - Is it ok?
    Module 19 Gateway
    • Select Installation List
    • Check 6C Rear View Camera
    • Save
    Module 09 Central Electrics
    • Select Coding
    • Go to Byte 35 and check Bit 4
    • Exit and Do it!
    Module 5F Multimedia
    • Select Adaptation
    • Search for VPS
    • Car_Funktion_List_BAP_Gen2_VPS set the new value activated and press Do it!
    • Car_Funktion_List_BAP_Gen2_VPS_msg_bus set the new value Terminal 15 and press Do it!
  1. C7 rear view camera retrofit
    By buddyboy in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 10-12-2020, 12:25 PM
  2. Replies: 0
    Last Post: 07-05-2017, 07:25 PM
  3. OEM Rear view camera retrofit
    By Dogjen in forum Passat - B8 Forum - 2015 -
    Last Post: 21-09-2016, 07:11 PM
  4. Overhead / top view camera retrofit
    By Q7quattro in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 22-12-2015, 08:51 AM
  5. Retrofit rear view camera - VW Sharan 7N 2013 model
    By Kit James in forum Retrofits
    Last Post: 04-03-2015, 03:20 PM
