Thread: Audi A3 TDi oil leak
  1. Angry Audi A3 TDi oil leak
    Jun 2018
    Cheshire
    My Audi A3 TDi went in for its MOT and they noticed there was an oil leak that could only be seen looking from the bottom upwards. On further investigation it appears to be coming from the timing belt area. So is it likely to be the camshaft or crankshaft seals ? I understand its easier to work on when the timing belt is removed. Would you normally do the job with a new timing belt and water pump at the same time ?
    Now my car is not old its only 2014 and covered a mere 30k miles. Surely this is not a common issue with a low mileage car ?
  2. Re: Audi A3 TDi oil leak
    Jul 2018
    Hello,
    Did you ever resolve this? I'm having the same issue on my EA288 2.0 TDI. Small leak around the bottom pulley on the driver's (UK) side.
    Thanks.
  3. Re: Audi A3 TDi oil leak
    Jul 2018
    Edinburgh, UK
    Have either of you had any luck with this?
    Mine was diagnosed with 'slight oil mist around crank pulley area' during it's service. Hasn't used any oil since it was last serviced (2 years ago on flexible). Car is a late 2014 2.0TDI with just 26k on the clock.
    Whilst I'm not overly concerned about it, I find is disappointing for a well looked after, low mileage and relatively young car.
  4. Re: Audi A3 TDi oil leak
    Jul 2018
    No I haven't had any luck with it yet. Going into the mechanic this week but he thinks it's the front main seal (crank seal).
  5. Re: Audi A3 TDi oil leak
    Jul 2018
    Front crank seal changed today so has hopefully solved the issue.
    Part number 04L103151
    My mechanic charged me £80 for part + £80 for around 2 hours labour.
  6. Re: Audi A3 TDi oil leak
    Mike McKinstry Guest
    -£80 seemed good ?!
  7. Re: Audi A3 TDi oil leak
    135 Post(s)
    2026 Post(s)
    £80 labour! The cam belt has to come off...
  1. Audi S3 Leak
    By jordankitch in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 04-12-2015, 08:01 PM
  2. Please Help Oil leak audi a4
    By nowheels1 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 02-02-2011, 11:29 PM
  3. Audi A4 1.9 TDI (110) Oil leak and Possible boost leak?
    By officialuk in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-02-2011, 10:45 AM
  4. Oil Leak On My Audi A4 3.0 QS
    By SHAZA4 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 22-04-2008, 11:16 PM
  5. Audi 80 leak
    By black a4 in forum 80 - 90
    Last Post: 28-11-2007, 10:50 AM
