Thread: Audi A4 3.0 v6 tdi manual 2005
  1. Audi A4 3.0 v6 tdi manual 2005
    Jun 2018
    Co durham
    Hi guys new to the forum
    Would ike to see hi and thank you to all who puts there support into this forum
    I have a Audi A4 3.0 tdi on a 2005 currently 195000 miles
    Problems encountered very recently
    Engine light on pulling code up to do with intake control circuit bank 1 failed
    Missfire rough idle
    Loss of pulling away power
    Oil dilution on a mega scale as in car holds 6.9 litres of oil it dropped out nearly 12 litres
    Oil all over top of engine where oil cooler erg sits
    Excessive deisel knock on one cylinder
    Roughly a litre of oil removed from inter coolers
    Turbo very very sight tingling on wine down
    Last but not least oil in expansion tank
    Asumptions so far
    Replace swirl flap actuator bank one
    Leaking injector injectors this causing knock misfire
    Oil cooler bust excessive oil leakage around cooler or seals under cooler
    System full of oil in places oil shouldn’t be
    Things I have already done
    Change actuator clears code
    Dropped all oils and coolant
    Cleaned out intake manifolds
    Intercoolers intake pipes from turbo through to manifolds removed egr cooler cleaned ready for replacement
    On with taking out oil cooler ready for replacement
    I have tested injectors for leakage and st least one is leaking past exsessively
    So the question I am asking is
    am I on the right tracks to get this car back on the road or is it coming towards end of life
    The car is in very clean condition inside and out
    With these problems the cars system won’t pull up any other codes only actuator
    Any help advise question deeply welcome and much appreciated
    Thank you to all
  2. Re: Audi A4 3.0 v6 tdi manual 2005
    Jul 2015
    Staffs
    46 Post(s)
    I would change the injector(s), oil change and flush, and take it from there.
    Ian
    A4 B6 Avant Nogaro Blue
  1. Audi A4 3.0 v6 manual 2005
    By Tim walton in forum Chat - Completely Off Topic
    Last Post: 03-06-2018, 05:41 PM
  2. Question Audi A4 3.0 tdi v6 manual 2005
    By Tim walton in forum New Member Introductions
    Last Post: 03-06-2018, 01:02 PM
  3. A6 2005 manual?
    By daftdock2 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 08-06-2017, 10:49 PM
  4. Service manual of aaaaaaavw bora 1.6L manual(2003-2005)
    By tolasam2002 in forum Bora - 1998 - 2005
    Last Post: 05-03-2014, 12:28 PM
  5. Workshop manual 2005 T5
    By 2005divad in forum The Commercial Range
    Last Post: 10-02-2009, 09:17 PM
