Thread: Changed front brakes. Now no brakes!
  1. Changed front brakes. Now no brakes!
    Jan 2011
    smallfield, next to gatwick
    Bought the car a couple of weeks ago. And new the front brakes needed doing. Replaced discs and pads. Compressed the piston in as I've always done. Then used a pressured container to replace the fluid. (one man tool) I sucked out the fluid in the reservoir first then flushed each corner . Started at the front. And did about 200ml per wheel. When driving home I noticed the brakes were petty naff. And just thought new brakes. Need bedding. the pedal pumps to a hard pedal. But when you need them, it goes to the floor. And I've had to pump them 3 times when coming to a junction. In order to get a good braking pedal. The brakes still do work, even when the pedal is right down low.
    I've done some research. And it's not looking like, "its just that" part.
    Some say new master cylinder. Some say keep bleeding. Some say. Plug it in and do a abs pump flush...
    Car was OK before. And didn't change rear brakes just bleed the system through. I did not remove or undo and part of the hydraulic section. Other than the bleed nipple.
    Used a whole 1lt to do the job.
    Car 58 plate 2.0tdi a6. Old style pd engine.
    audi a6 avant 2.0tdi (pd) 58 plate.
  2. Re: Changed front brakes. Now no brakes!
    May 2008
    40 Post(s)
    Did all thre pistons retract effortlessly?
    I think I would jack each corne rup remove the wheel and see how much free play each calliper has.
    If you think about it logically if its got air in it the pedal will not pump up hard, the fatc it needs pumping says to me something is sticking and the act of pumping forces it free and when you release the pedal the something goes back to its previous position.
    Could aslo be disc runout knocking the pads back into the calliepr as the wheel rotates.
  3. Re: Changed front brakes. Now no brakes!
    131 Post(s)
    1973 Post(s)
    You may have pumped a litre or so of fluid but you have air trapped in there which needs a 1.5Bar pressurised bleeding system to remove.
  1. Please Help Changed brake pads discs and calipers...brakes not working
    By Jacqui1980 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-06-2015, 07:25 AM
  2. Please Help Changed front pads and now some mornings get red BRAKES symbol flashing at me
    By 20vcqdriver in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 24-03-2012, 11:09 PM
  3. Replies: 0
    Last Post: 26-12-2010, 04:08 PM
  4. changed temperature sensor not no servo assist on brakes
    By waynetdi130 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-02-2009, 02:32 PM
  5. front brakes
    By markram in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-04-2008, 10:07 PM
