Thread: touran rear wheel baring
  1. touran rear wheel baring
    Aug 2014
    uk
    is this job the same as the golf? any guides, id like to double check before i get stuck in
  2. Re: touran rear wheel baring
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    make sure you can get the pad carrier bracket off, as I don't think you can get the disc top hat off the the hub with the bracket still in place, those bolts are tight as hell, and be aware you are meant to replace the torque to yield bolts.
  3. Re: touran rear wheel baring
    Aug 2014
    uk
    I had it off before when done the discs, used the same bolts again..
    Is it just one splined bolt holding the baring/hub on? Can heat be used if needed?
  4. Re: touran rear wheel baring
    134 Post(s)
    2007 Post(s)
    There is an M18 XZN behind the cap which MUST be replaced. The bolt sticks out of the back of the hub and needs cleaning and lubricating there before removal or you can rip the thread out of the hub carrier, we always run a chaser tap down the thread when the bolt is out. The torque spec is 180Nm plus 180 degrees which means you need a very long lever. The first M18 I bought snapped as I was getting near the angle and I ended up as a crumpled heap on the floor so I bought a genuine one.
  5. Re: touran rear wheel baring
    Aug 2014
    uk
    a new bolt should come with the new hub. it wont be a gen vw part though.. did you use an impact gun removing, or didnt risk it incase stripped teeth? refitting, did you use some thread lock , or just torque it up
  6. Re: touran rear wheel baring
    134 Post(s)
    2007 Post(s)
    The new bolt in a Febi kit comes with goo applied.
    Bad tool , good tool
  7. Re: touran rear wheel baring
    Aug 2014
    uk
    Already had these Clarke ones, done the job. There was abit blue on the end of the new bolt. Thanks for the help
  1. Replies: 0
    Last Post: 07-03-2016, 01:47 PM
  2. Replies: 14
    Last Post: 27-02-2015, 11:08 PM
  3. r32 steering wheel on touran
    By hardtail in forum Vehicle Security - Retrofit / aftermarket alarms & immobilisers
    Last Post: 03-03-2014, 08:41 PM
  4. Question Touran Rear wheel alignment
    By gbdxo in forum Touran - Sharan - Caravelle
    Last Post: 13-09-2011, 11:13 AM
  5. Changing a touran rear wheel bearing
    By ermck1 in forum Touran - Sharan - Caravelle
    Last Post: 15-09-2009, 02:42 PM
