Thread: 1.9tdi AWX loss of throttle
Results 1 to 10 of 15
  1. 1.9tdi AWX loss of throttle
    Tewkesbury
    A VERY intermittent problem. Throttle fails to respond, come totally off the pedal, then control returns. ESP light comes on, usually goes off when up to speed, but sometimes stays on until shutdown. Fuel consumption and performance have not changed. It usually happens when coming out of a car park or other slow speed stuff.
    Engine ECU fault codes are:
    18039/P1631 - Accelerator Position Sensor (G79): Signal too High
    17553/P1145 - Mass Air Flow Sensor (G70): Short to Plus
    Pedal has been replaced.
    Hair now being torn out!
  2. Re: 1.9tdi AWX loss of throttle
    131 Post(s)
    1979 Post(s)
    This is usually water damage to the ECU.
  3. 1.9tdi AWX loss of throttle
    Tewkesbury
    Today it got worse. Thirty miles on the motorway with no problems. Back on the A roads and it was terrible. Limped to my mums house and called the AA.
    He read the same faults as me and suggested it was either the MAF or the pedal!
    Limped home with him following. Swapped the pedal back to the old one, still the same faults. Cancelled holiday.
    Disconnected the MAF, the only fault code showing is:
    17552/p1144. Mass air flow [MAF] sensor-670pen/short to ground
    But, it's drive able, a bit dull but still better than the Ibiza 1.2. No warning lights on.
    New MAF on Monday.
    Edited to add: no indications of water near the ECU.
  4. Re: 1.9tdi AWX loss of throttle
    Tewkesbury
    New Bosch MAF fitted, fault codes cleared.
    GPS derived HP was 60 previously, now it's 114. Plenty of towing tests to give it a load, but it's looking good.
  5. Re: 1.9tdi AWX loss of throttle
    Tewkesbury
    Quote Originally Posted by morticiaskeeper View Post
    Update.
    A thousand miles later, the throttle went again. Fault code said position sensor. Steadily got worse, so changed the pedal, still bad. Only got home from holiday with the cruise control.
    Struggled to reverse onto drive, glow plug lights showing, MAF fault code appears again, as does a low voltage code which then disappears.
    Chasing a possible earthing problem now, and scouring the ads for a reliable day van!
  6. Re: 1.9tdi AWX loss of throttle
    131 Post(s)
    1979 Post(s)
    Have you checked the ECU plug and pins for water damage?
  7. Re: 1.9tdi AWX loss of throttle
    Tewkesbury
    No signs of water damage in the ECU box, but I will revisit it.
    The MAF & Pedal share an earthing loom, so I'm going to investigate that tomorrow night.
  8. Re: 1.9tdi AWX loss of throttle
    131 Post(s)
    1979 Post(s)
    Unplug the ECU and check the pins for corrosion.
  9. Re: 1.9tdi AWX loss of throttle
    Tewkesbury
    Watched the throttle position reading fluctuate last night. Also had a voltage warning on the pedal.
    I spoke to a customer of mine today and they are going to take a look on Thursday.
    It started doing this just after the big snows in March, further pointing to contacts.
  10. Re: 1.9tdi AWX loss of throttle
    Tewkesbury
    All connections seem good, but the ecu has a burning smell behind the smaller connector :-(
    Sent from my SM-G900F using Tapatalk
  1. Please Help Occasional loss of throttle response above 2500 rpm
    By Mikeybs in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-10-2013, 09:38 PM
  2. loss of throttle pedal tempararly
    By scootermap in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 20-12-2010, 10:34 PM
  3. Important Power Loss / Turbo loss on VW Passat 1.9TDI
    By mubsy812001 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-06-2010, 03:14 PM
  4. Please Help loss of throttle response
    By adam8198 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 07-08-2008, 08:59 PM
  5. Help! Allroad with loss of throttle
    By Giraffe in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 23-10-2007, 09:41 PM
