Thread: A1 1.6tdi idle at 1600rpm?
  1. A1 1.6tdi idle at 1600rpm?
    Apr 2016
    peterborough
    Hello guys
    first time I ever come across this weird issue, car on cold start will start up normal and idle at around 800rpm. As long as I am gone for a drive it no longer idles at 7-800rpm it will now idle at 1600rpm. There are no fault codes in the system and I initially thought it may have something to do with car being stuck in DPF regen mode however I know if it was stuck in Dpf regen mode the main fan would always be on but the fan doesn’t come on so it can’t be that.
    anything else worth checking? I was thinkin possibly a sticking throttle body?
  2. Re: A1 1.6tdi idle at 1600rpm?
    2002 Post(s)
    The throttle flap has nothing to do with fueling, the engine speed is controlled by injection volume.
  3. Re: A1 1.6tdi idle at 1600rpm?
    Feb 2020
    Bradford
    40 Post(s)
    Check air temp sensors. The theory being if it thinks your freezing it may add rpms to compensate
  1. Rough idle A1 1.6tdi
    By Jakefr in forum A1
    Last Post: 02-07-2020, 10:16 PM
  2. 1.6TDI Idle Speed
    By TDiBoraSam in forum Golf MK6 - 2009 - 2013
    Last Post: 12-03-2015, 02:27 PM
  3. Lumpy idle, high idle revs at times, using more petrol - 2003 A4 1.8T
    By iano in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-11-2014, 07:16 PM
  4. No grunt below 1600rpm 2.5tdi AKE with auto box
    By Golf tdi Hal in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 28-03-2013, 06:39 PM
  5. 2.0tdi Multi - Vibration noise between 1400-1600rpm?
    By 5678 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 11-01-2013, 07:16 PM
