Thread: My Golf BKD Idle Judder / Misfire Issue
Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
  1. Re: My Golf BKD Idle Judder / Misfire Issue
    #21
    Mar 2017
    Nottingham
    9 Post(s)
    Mine had a nasty shake on idle before Vw done my timing belt came back with a torsion value of -2.5 idle was perfect so left it at that
  2. Re: My Golf BKD Idle Judder / Misfire Issue
    #22
    Nov 2016
    Ireland
    14 Post(s)
    "Firstly, check the software version of the ECU is the optimized level to deal with this issues, I can help you on this if you mail me your reg number. "
    @ Crasher - I seen you posted the above comment in another thread regarding this same issue a while back (I was searching this topic.) Can you check my software version if I give you my reg or chasis number. I saw a mention of a software update in my owners handbooks that the previous owner had done or checked at some point. I think the car was fairly new when that entry was made though so probably nothing to do with this issue.
    I've ordered the timing tools so will check that first and update then.
  3. Re: My Golf BKD Idle Judder / Misfire Issue
    #23
    1841 Post(s)
    With the reg and can see if there are any updates to the level numbers but not which one it has. A VCDS scan shows the update level.
  4. Re: My Golf BKD Idle Judder / Misfire Issue
    #24
    Jul 2016
    United Kingdom
    Hi, noticed you updated the thread, I still have a bit of idle judder on my car still but it has improved after adjusting the exhaust side cam slightly.. I noticed on mine that it had actually slipped over somehow as you could see where the 3 bolts used to be tightened down. I'm gonna revisit it soon and try to set it all up properly as I need to replace the cambelt anyway really. Definitely seems to be a timing related issue with these though in my opinion, Crasher knows what he's talking about more than me though I'm just a hobby mechanic.
  5. Re: My Golf BKD Idle Judder / Misfire Issue
    #25
    Jun 2022
    Walsall
    I have a golf gt 1.4 tsi 170
    what is was all fine at start of buying it the started juddering misfiring and engine management light started flashing now stuck on but next day when start up it will be off then it’ll do alll same again, pulled out one the coil packs and had all oil in there but other 3 was clean not sure what could’ve up with
  6. Re: My Golf BKD Idle Judder / Misfire Issue
    #26
    1841 Post(s)
    @Smiler93, Please start your own thread, this one is three years old and about a Diesel.
  1. Wobble / judder on idle issue.....
    By Stellamandude in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 03-05-2015, 10:45 PM
  2. Help :( white smoke misfire/judder idle
    By Turbo_scotty in forum A8 - S8 - V8
    Last Post: 20-04-2014, 01:17 PM
  3. 2.0 tdi bmn / bkd engine idle misfire/judder PLEASE HELP!!!
    By GTRUSS in forum Golf MK5 - 2004 - 2009
    Last Post: 09-09-2012, 04:34 PM
  4. Golf Mk4 2.0 Gti judder / misfire? - help!
    By ian davies in forum Golf MK4 - 1999 - 2004
    Last Post: 19-04-2008, 05:45 PM
  5. The msterious golf Mk3 Judder/misfire problem!
    By johnny80 in forum Golf MK3 - 1993 - 1999
    Last Post: 28-08-2007, 10:12 PM
