Thread: Got my audi a6 EGR???
  1. Got my audi a6 EGR???
    Jun 2007
    Hi everybody, I got audi a6 1.8T auto, T - reg., I got problem for few weeks, my car hesitated under acceleration, I replace turbo for new one, new Lambda sensor, MAF sensor, DV valve - miltek , clean throttle body, replace all vacuum pipe, check everything for leaks,everything is just fine, but car still hesitated, I don't know what can I do, I find here on forum, maybe can be EGR, but I don't know if I got one, can anybody help, or where can I find, if got my car one or not??? Thank you very much for any help..., or advice..., thanks...
  2. Re: Got my audi a6 EGR???
    Canada
    I can help with one thing, it will have an egr valve
  3. Re: Got my audi a6 EGR???
    Jun 2007
    Hi mate, thanks for help, can you let me know what car you got? Thanks...
  4. Re: Got my audi a6 EGR???
    Canada
    Oh i got a A4 1.9TDI AFN 110bhp...Now I re read and you've got a petrol, so I'm stumped
  5. Re: Got my audi a6 EGR???
    Jun 2007
    No problem mate, still thanks for respond, now I got on my vag com 17963 code, I start thinking about my chip maybe is faulty, I chipped my car nearly half year ago, everything was just fine, but last 2 months I gopt hesitation, I checked error codes was clear - no faults, I replace turbo for new one, new lambda, DV, MAF, Throttle, still hesitation, I now my vag com start showing 17963, and looks like car got more boost as it's needs...., , then I keep looking what can be wrong, I love my car, I will do everything , will be ok again..., and few options left : egr, upgrade chip, ecu, etc. ...
  6. Re: Got my audi a6 EGR???
    Oct 2007
    17963/P1555 - Boost Pressure Control: Upper Limit Exceeded
    Possible Symptoms
    Reduced power output
    Limp mode
    Possible Causes
    Boost Pressure too High
    Hoses/Pipes incorrect connected, disconnected, blocked or leaking
    Charger Pressure Control defective
    VNT (variable nozzle turbo): nozzles stuck
    Solenoid Valve for Boost Pressure Control (N75) defective
    Possible Solutions
    Check Hoses/Pipes to/between Components
    Check Solenoid Valve for Boost Pressure Control (N75)
    Check / Clean / Replace Charge Pressure Control
    Check / Clean mechanism for variable nozzles
    Hope this helps
  7. Re: Got my audi a6 EGR???
    Jun 2007
    Thank you very much for your help, just 2 days ago, I find, inside the one of the pipe N75 was very small piece of rubber, and that make all trouble - hesitation, surging, loosing power .., now I replace my N75 F valve with N75J valve, and its much much better , no any trouble at all, thank again for your help...
