Thread: Golf Plus 2.0 TDI 2012/62 Plate Blocked DPF Help needed VW quoted £2400 to replace!!!!!! HELP NEEDED!!!
  1. Question Golf Plus 2.0 TDI 2012/62 Plate Blocked DPF Help needed VW quoted £2400 to replace!!!!!! HELP NEEDED!!!
    Aug 2006
    I have a Golf Plus 2.0 TDI 2012/62 Plate which has done only 42,000 miles. The DPF two warning lights came on and the engine management light as well. When I am driving it, it feels like it is on limp mode and cannot
    pickup at all. I took it to my local VW garage and they said I need a complete replacement DPF for it as it is completely blocked and cannot be regenerated. I tried to take it to a Halfords garage before when the light first
    came on but they could not do a force regeneration. It seems my local VW want me to go down the expensive route. I was told that it was rare to have a car with a DPF issue and it must have been the way I drove it. I drive locally, A & B roads and the occasional motorway journey so I was surprised that at 42k miles it went.
    I was also told that some garages have a cheap way of removing the blockage in the DPF - Does anyone know a cost effective way of getting my car back to normal performance and getting rid of the lights? I don't want to replace the DPF filter due to the expense - anyone experience a similar problem?
    I would really appreciate the advice
  2. Re: Golf Plus 2.0 TDI 2012/62 Plate Blocked DPF Help needed VW quoted £2400 to replace!!!!!! HELP NEEDED!!!
    May 2012
    Everywhere
    308 Post(s)
  3. Re: Golf Plus 2.0 TDI 2012/62 Plate Blocked DPF Help needed VW quoted £2400 to replace!!!!!! HELP NEEDED!!!
    Jul 2011
    Near Uxbridge
    Quote Originally Posted by Gazwould View Post
    But all the above now is illegal and an instant MOT failure isn't it? Hence the 'off road use only' warning on the invoice.
    Sent from my SM-G955F using Tapatalk
    Consultation en ligne viagrasansordonnancefr.com immunite des francais
  4. Re: Golf Plus 2.0 TDI 2012/62 Plate Blocked DPF Help needed VW quoted £2400 to replace!!!!!! HELP NEEDED!!!
    May 2012
    Everywhere
    308 Post(s)
    The square hole is cut and welded facing the engine on a blind side where a tester can't see .
    Then there's VIN plate manufacturers smoke coefficient numbers.....
  5. Re: Golf Plus 2.0 TDI 2012/62 Plate Blocked DPF Help needed VW quoted £2400 to replace!!!!!! HELP NEEDED!!!
    Sep 2011
    Kilmarnock, United Kingdom
    12 Post(s)
    Quote Originally Posted by iworld View Post
    Search for your nearest terraclean garage or mobile DPF cleaners
  6. Re: Golf Plus 2.0 TDI 2012/62 Plate Blocked DPF Help needed VW quoted £2400 to replace!!!!!! HELP NEEDED!!!
    Aug 2006
    I know someone with a similar problem
    Here a couple of things you can try
    1) a Mechanic can manually remove the SOTT and do a force regen, but the likelihood is that it will come back again
    2) try some DPF cleaner that will clean the soot, you need to run the car in 3rd gear at 50mph for 10-15 minutes for it to burn it off
    3) Use Shell optimax diesal in conjunction with the above
    If the above do not work then the likelihood is to replace the DPF Unit.
    I am sure there are good mechanic out there that know a way around this issue.
  7. Re: Golf Plus 2.0 TDI 2012/62 Plate Blocked DPF Help needed VW quoted £2400 to replace!!!!!! HELP NEEDED!!!
    131 Post(s)
    1976 Post(s)
    I hope after four years this is resolved but almost any blocked not physically damaged DPF can be cleaned off the car, DPF Clean Team are excellent at this job saving my customers thousands AND remaining legal not pumping life threatening particulates into the air.
  1. What is needed to replace cam cover gasket/seal?
    By rhencullen1989 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 29-05-2014, 08:59 PM
  2. Please Help Help needed to replace fuel cap locking solenoid
    By battmiceter in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 17-04-2013, 12:41 PM
  3. Replies: 12
    Last Post: 12-07-2011, 10:38 PM
  4. A3 05 plate spare kit needed
    By slinxy in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 31-03-2009, 08:24 PM
  5. Golf 2005 plate oil light has come on advice needed
    By verachion in forum Golf MK5 - 2004 - 2009
    Last Post: 13-08-2008, 12:18 PM
