Thread: Start/stop switching to early. + Hide MMI Screen.
Results 1 to 10 of 10
  1. Start/stop switching to early. + Hide MMI Screen.
    Jan 2013
    Tonsberg, Norway
    21 Post(s)
    after couple of months of using A6 C7 facelift (2015) I have few questions. I hope its better to ask them all here instead of 2 new threads.
    1. Is it possible to adjust speed when Start/stop system switches on. Now it turns on even when the car is till rolling, like 3km/h and that is a bit strange, its not like the car came to complete stop. Or maybe if its possible to adjust amount of time to pass after stop. Cause now it turns on right after I stop even for couple sec.
    So I wonder if its possible to adjust these settings, make like 10 sec delay before turning engine of. Its getting annoying when it starts stop every 5 meter in a traffic.
    2. Also is it possible to keep MMI screen hidden and show it only after push of a button? So that when I start the car its hidden and comes out only when I want.
  2. Re: Start/stop switching to early. + Hide MMI Screen.
    Sep 2009
    Preston
    54 Post(s)
    1. It does this on mine too. I used OBDeleven to switch the start/stop function so it's initially off until I press the button. I never use start/stop though unless I'm sat in a jam.
    From Apr 2017 - now: Oct 2016 (66) Audi A7 3.0 TDI quattro (FL - MY17), 272 ps, Black Edition (Tech pack, Parking Pack, Folding Mirrors), Mythos Black.
    Gone - From Oct 2013 - Mar 2017:
    Mar 2013 Audi A6 C7 S-line 2.0TDi Manual, Daytona Grey.
    (Gone) - From Sep 2011 - Oct 2013
    : Sep 2010 Audi A6 C6 S-line Special Ed (Le Mans) 2.0 TDi Manual, Polar Blue./(Gone) - From Sep 2009 - Sep 2011: Sep 2008 Audi A6 C6 S-line 2.0 TDi Auto, Akoya Silver.
    0 2 0
  3. Re: Start/stop switching to early. + Hide MMI Screen.
    Mar 2014
    Edinburgh
    235 Post(s)
    1. No. The facelift has an extremely aggressive stop start to achieve the emmision goals. There’s a button on the dash to stop it going. Or you can use vcds to reverse the switch so it only comes on if you turn it in with the button. I read somewhere that the new c8 can trigger stop start at 15kmh.
    2. Mmi screen in mine seems to keep the memory of its last state so if I turn off the car with it closed when I start again it’s closed.
    The screen will open when you reverse so don’t put stuff on top of it.
  4. Re: Start/stop switching to early. + Hide MMI Screen.
    Oct 2016
    woking uk
    any idea how this is initiated ?
  5. Re: Start/stop switching to early. + Hide MMI Screen.
    Mar 2014
    Edinburgh
    235 Post(s)
    Quote Originally Posted by mikeruss View Post
    It was like this from the factory. I have the tech pack if that makes any difference
  6. Re: Start/stop switching to early. + Hide MMI Screen.
    Jan 2013
    Tonsberg, Norway
    21 Post(s)
    Quote Originally Posted by A6S View Post
    I know about the button I would like to keep that on just adjust the wait time so if am am sitting at the lights for say 5-10 sec the turn of. Now its like i stop to get in to reverse gear and it shut down already.
    I dont think its healthy neither for a car or the enviroment such stop start cycles.
    Will try the close the screen when parked to see if it opens next time I start. It just I always reverse park so...
  7. Re: Start/stop switching to early. + Hide MMI Screen.
    Jul 2016
    Chestfield kent
    81 Post(s)
    Hi Have had a play with this today. 2015 FL Tech Pack. Closed MMI with button went for a drive inc reversing, during which the screen opened then closed once moving forward. Stopped turned off, locked the car, opened it up, turned on and screen pops up. So no memory for that. I am assuming that may be correct from locked to locked, as if at a new startup there is any info for the driver the screen is up to display it. Could it be that it memorises it if the car is not locked as only locking the car again would complete a cycle, ( i.e. from no power to no power again). Is this helping or confusing the question posted ???
  8. Re: Start/stop switching to early. + Hide MMI Screen.
    May 2009
    Ramsey, New Jersey, USA
    69 Post(s)
    Did you use the "close screen" button or did you press and hold the volume knob to completely power off the MMI?
    MF.
    Now: E 53 AMG 4MATIC
    / Q5 2.0TFSi Prestige
  9. Re: Start/stop switching to early. + Hide MMI Screen.
    Jul 2016
    Chestfield kent
    81 Post(s)
    Hi MFGF. Closed screen using the button at the side of the dash. Did not know about the volume button option.
  10. Re: Start/stop switching to early. + Hide MMI Screen.
    Jan 2013
    Tonsberg, Norway
    21 Post(s)
    Tried closing, driving and parking, still opened next time I started the car.
    turning off mmi is not an option, will have radio, music, navigation on.
  1. Stop / start cutting in early
    By RhysoTDI in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 09-11-2016, 08:55 PM
  2. Switching off automatic mmi screen opening using VCDS
    By jbmercapple in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 14-12-2015, 03:35 PM
  3. Please Help Golf V5. Wipers stop middle of screen.
    By JohnHuson in forum Golf MK5 - 2004 - 2009
    Last Post: 04-08-2009, 02:58 PM
  4. a3 stop anywhere on the screen wipers
    By turbo p in forum Audi A3 - Archive Topics
    Last Post: 24-04-2009, 05:56 PM
  5. When i want to have a ramp the MPG screen tells me to STOP!
    By Hotrocks888 in forum Golf MK4 - 1999 - 2004
    Last Post: 15-11-2008, 01:18 PM
