Thread: 1.6 FSI temperature gauge needle always at bottom
  1. 1.6 FSI temperature gauge needle always at bottom
    Apr 2018
    Doncaster
    I bought a MK5 Golf FSI 1.6 a couple of weeks ago and have noticed that the temperature gauge needle never moves from the bottom. I assumed that it’d be the Coolant Temp Sensor that was faulty, so I bought one, and fitted it, but it hasn’t seemed to have solved the problem.
    I’ve also noticed that the coolant level has been dropping very slowly over the past two weeks. I’ve checked the oil, and there doesn’t seem to be any sign of water in it, so I’m fairly sure there isn’t a problem with the head gasket, I’m just wondering where to look next. The engine does get hot, as the heaters blow hot air out, so I’m not sure it’s a problem with the thermostat either. Any pointers would be appreciated!
  2. Re: 1.6 FSI temperature gauge needle always at bottom
    131 Post(s)
    1976 Post(s)
    You need some diagnostic work with a full car scan and some observations of measuring block data in the engine and instruments addresses to view the temperature senders signals. A simple output test would show if the gauge needle moves as it should. The Golf 5 is VERY prone to leaking on the radiators left lower corner.
  3. Re: 1.6 FSI temperature gauge needle always at bottom
    Apr 2018
    Doncaster
    I have a Snap On Solus diagnostic computer I’m pretty sure I can get live data from that. I’ll get that plugged in when I can and see if I can get some readings. I have noticed a small wet patch on the ground near the left hand side of the radiator which appears overnight, so I’ll check that out also. Thanks a lot
  1. Temperature gauge needle not glowing
    By Nard666 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 09-04-2018, 09:47 PM
  2. Please Help Temperature Gauge Needle - No Reading
    By cka4 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 30-03-2011, 03:27 PM
  3. Question Gauge needle sweep
    By Soot1e in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 23-09-2009, 10:04 AM
  4. Temperature gauge reading lower than actual temperature
    By garymansell in forum Golf MK3 - 1993 - 1999
    Last Post: 24-08-2009, 04:29 PM
  5. Boost Gauge Needle Twitching
    By twign in forum Golf MK4 - 1999 - 2004
    Last Post: 20-11-2008, 03:06 PM
