Thread: Air Con Fault “A/C press/temp Sensor” “004 No signal/communication”
Results 1 to 10 of 10
  1. Air Con Fault “A/C press/temp Sensor” “004 No signal/communication”
    Feb 2013
    Uk
    38 Post(s)
    Tried using my AC today, but it’s stopped working , done a scan and the following error has come up ,
    00256 A/C pressure temperature Sensor (G395)
    Has anyone had the same error code ? Or can someone advise.
    will check fuses tomorrow-
    Many thanks
    Pic of fault
  2. Re: Air Con Fault “A/C press/temp Sensor” “004 No signal/communication”
    Aug 2009
    Usa
    6 Post(s)
    98 Post(s)
    Its referring to the pressure sender 4H0959126B Ł66.01 They are known to go faulty across the various audi platforms. It can be replaced with the circuit still fully charged as its a self sealing valve. Only other thing it could be is a break in the wiring.
  3. Re: Air Con Fault “A/C press/temp Sensor” “004 No signal/communication”
    Feb 2013
    Uk
    38 Post(s)
    Quote Originally Posted by morski View Post
    Hi morski , thx for the reply
    i did some research on this yesterday and came to the same conclusion. I’ve checked the connections, all look good.
    ordered part.
    any idea if the pressure sender comes with the “O” ring ? As the O ring has a different part number
    part number for O ring is 7H0820896. I’m having difficulty in finding this part , so hopefully it will come with the sensor
  4. Re: Air Con Fault “A/C press/temp Sensor” “004 No signal/communication”
    Aug 2009
    Usa
    6 Post(s)
    98 Post(s)
    No its sold separately. Ł1.08 so no partying tonight!
  5. Re: Air Con Fault “A/C press/temp Sensor” “004 No signal/communication”
    Feb 2013
    Uk
    38 Post(s)
    Funny!!!!
    Can’t find the part online(not on Audi .co. . U.K. parts site but they have the sensor ! , any suggestions ?
    thanks morski
  6. Re: Air Con Fault “A/C press/temp Sensor” “004 No signal/communication”
    Aug 2009
    Usa
    6 Post(s)
    98 Post(s)
    Why? where do you normally your parts from? Its definitely listed on the parts diagram
  7. Re: Air Con Fault “A/C press/temp Sensor” “004 No signal/communication”
    Mar 2018
    GB
    19 Post(s)
    Just get them to order the ring as he's given you the part number they shouldn't have a problem. Phone them up and tell them.
    Sent from my SM-G900F using Tapatalk
  8. Re: Air Con Fault “A/C press/temp Sensor” “004 No signal/communication”
    Sep 2015
    Forres, Scotland
    23 Post(s)
    I replaced this sensor on my previous A6 C6 and bought from Audi. It came with oring on. On A6 C6 Is located behind bamper on right side of radiator. You have to remove from bamper and need spanner size 32 or 34 size.
  1. Steering Angle Sensor No Signal/Communication - G85 - 2002 A3 - 8L 1.8T
    By GrantBuchanan in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 03-04-2016, 11:35 AM
  2. Please Help 16500 - Engine Coolant Temp. Sensor (G62): Implausible Signal
    By SkipFeeney in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-09-2012, 08:44 PM
  3. Question Bora - Engine judder when driving - MAF sensor, temp. sensor or ABS fault??
    By Christo3000 in forum Bora - 1998 - 2005
    Last Post: 20-06-2011, 05:29 PM
  4. Please Help Fault Found: 01170 - Fuel Injection Duration Sensor (G175) 03-00 - No Signal
    By dylins in forum Golf MK3 - 1993 - 1999
    Last Post: 28-11-2009, 10:36 AM
