Thread: Air conditioning
  1. Air conditioning
    Hi guys.
    Got in my 2014 Superb elegance today after work and realised due to the sweat blinding me on the way home that the fan is not working. Have checked the fuse but this seems fine and even when i swapped with 20A (it is 10A) still no wind. Can anyone shed any light/point me in the right direction. If it's gonna continue to be this warm i NEED wind and I can't find much online.
    i should add it's just had an MOT and i'm sure it was working prior to that?
  2. Re: Air conditioning
    Jul 2015
    Staffs
    46 Post(s)
    You need to scan for codes to pinpoint the problem.
    Ian
    A4 B6 Avant Nogaro Blue
  3. Re: Air conditioning
    Quote Originally Posted by rowdy-999 View Post
    Turns out it was a simple fix. Had found some brief detail on the blower motor seizing so i dug around behind the glove box which was very easy to remove and refit (only broke 1 locating pin so a win as far as i'm concerned). Found the blower and removed with a simple rotation in a plastic housing. Free'd it all up with a variety of fluids ;-) as it was obviously very stiff and gave it a cursory spray with contact cleaner and it now blows like a goodun again. Yay! What is not so yay is the fact that i unplugged the airbag in the process so now i need to clear a code i think. Am i correct in thinking Rowdy that the fault is held until i do this or have i caused some damage or something? Certainly didn't notice anything as i was working. If so can you recommend a bit of kit that is good and suitable and not £1000 pounds?
  1. Air Conditioning A4 B5 TDI
    By jacksticks in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-05-2018, 11:50 AM
  2. Very Hot Air Conditioning
    By jwalman in forum Golf MK4 - 1999 - 2004
    Last Post: 20-02-2010, 04:51 PM
  3. Air Conditioning
    By asm51 in forum Golf MK6 - 2009 - 2013
    Last Post: 13-09-2009, 09:43 PM
  4. Air conditioning
    By tania joubert in forum Golf MK5 - 2004 - 2009
    Last Post: 05-07-2009, 11:15 AM
  5. Is it possible to add air conditioning?
    By flying fish in forum The Commercial Range
    Last Post: 16-08-2008, 05:59 PM
