Thread: Weirdest vibration issue !!!
Results 1 to 10 of 13
  1. Weirdest vibration issue !!!
    Oct 2007
    I have a 2010 2.0 tdi A5 which has recently developed a really weird fault. I do the same commute to work every day and after roughly 10-15 minutes of driving, while I'm on the motorway, a vibration starts through the steering wheel along with a low frequency drone. At first I thought wheel balancing but it disappears after around a minute and doesn't come back for the rest of the journey (around 40 minutes). It doesn't seem to be speed related either as I've slowed down/sped up etc but still the same. I've also dipped the clutch to make sure it's not dual mass flywheel related. I had the wheels balanced as a matter of course but still no good. Really strange fault and quite annoying, anyone got any ideas ?
    Cheers,
    JJ.
  2. Re: Weirdest vibration issue !!!
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    At the risk of saying something stupid, could it be a section of motorway road surface, failing that have you tried swapping front wheels to back?
  3. Re: Weirdest vibration issue !!!
    2009 Post(s)
    The MLP platform is very prone to lower ball joint wear which causes odd wheel vibrations and we are starting to see a few racks fail due to internal wear on early cars like yours.
  4. Re: Weirdest vibration issue !!!
    Oct 2007
    Thanks for the reply Rob69 but no, it happens on different sections of road but always after about 15 minutes driving. I could swap the wheels but can't get my head around the fact it dissappears after a minute or so ??!!
  5. Re: Weirdest vibration issue !!!
    Oct 2007
    Thanks Crasher, I'll certainly have a look at the lower ball joints but still don't understand how the problem disappears ?!!
  6. Re: Weirdest vibration issue !!!
    2009 Post(s)
    That could suggest a heat related change in something which would normally point to a tyre, what is it on?
  7. Re: Weirdest vibration issue !!!
    Oct 2007
    So the car is a 2010 2.0 tdi Sport running on 245/40/R18. I've given the tyres a once over and no sign of flat spotting or uneven wear. I'll give the lower ball joints a look this weekend though and then maybe go for tyres.
  8. Re: Weirdest vibration issue !!!
    2009 Post(s)
    What make and version of tyres?
  9. Re: Weirdest vibration issue !!!
    Oct 2007
    Yokohama AE50 (W Rated)
  10. Re: Weirdest vibration issue !!!
    2009 Post(s)
    Not known for carcass issues so ball joints and rack play check first
  1. Please Help Vibration issue after remap / tuning box
    By skyegtb in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 19-12-2020, 05:18 PM
  2. Weirdest defect i have ever seen: Metal plate appeared in fuel filler
    By robbyg in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 08-01-2017, 11:18 PM
  3. Please Help A6 tdi 2,0 2007 vibration. Timing issue?
    By edfl in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 26-11-2015, 11:01 AM
  4. audi a6 3.0tdi avant tiptronic vibration issue
    By jp33 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 16-09-2015, 08:59 AM
  5. S4 v8 vibration issue ?
    By buck22 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 12-11-2009, 09:56 AM
