Thread: DPF Regen im 5th gear
  1. DPF Regen im 5th gear
    Apr 2018
    Swansea
    I have owned an A3 8p 1.9 TDI e for a month and today invested in a VCDS from an official supplier.
    I run full diagnostics and cleared a few codes nothing major.
    I then proceeded to check the DPF stats. The Particle Filter Load Coefficient was at 34g despite the fact I had just been on a long run a few days back.
    I then proceeded to regen whilst driving. The car was already up to temp. All electrics switched on. Motorway in 4th gear at 2500rpm - nothing. Up to 3000rpm - nothing. Dropped to 3rd and kept 3000rpm and increased a little - nothing. Actually during this time the load increased to 35g. I thought well its time to head home so changed up to 5th gear doing 80mph at just over 2000rpm and the load fell like the titanic.
    All the advice of how to clear the dpf turned out to be tripe. Why did mine only clear in 5th at 2000 rpm?
    Weird.
    Going to keep an eye on it in next few weeks.
    My biggest fear is the garage I bought the vehicle did not put low ash PD oil in. May change it myself to be sure.
  2. Re: DPF Regen im 5th gear
    May 2012
    Everywhere
    308 Post(s)
    What did they put in ?
  3. Re: DPF Regen im 5th gear
    134 Post(s)
    2012 Post(s)
    Which login code did you enter to initiate forced regen whilst driving? The load coefficient can go high no matter what oil is used. Which version of VCDS are you using?
  1. Dpf regen
    By Stbb748 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 23-05-2018, 05:23 PM
  2. DPF regen
    By fronty in forum Q7 - 4M Forum - 2016 -
    Last Post: 29-12-2017, 02:59 PM
  3. dpf regen
    By dieselal in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 15-02-2016, 10:16 AM
  4. Dpf regen
    By Chuck32 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 22-03-2014, 08:18 PM
  5. DPF Regen
    By Sportwag in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 03-01-2012, 06:42 PM
