Thread: stupid question about turbo's
Results 1 to 10 of 10
  1. stupid question about turbo's
    do they work properley straight away or do they need runnunig in?
  2. Re: stupid question about turbo's
    May 2007
    knee deep in clunge
    14 Post(s)
    I would run it in and allow the engine to idle before turning the engine off to prevent oil starvation to the turbine shaft as it spinning at 100,000rpm aprox.
  3. Re: stupid question about turbo's
    ok good stuff, so will it be more responcive in time?
    cos me car dontvseem as fast as it used to be..
  4. Re: stupid question about turbo's
    Canada
    Can we assume you've just had a new turbo fitted? a little more detail may help
  5. Re: stupid question about turbo's
    May 2007
    knee deep in clunge
    14 Post(s)
    It will last longer if allow the engine to idle before turning off,as for the performance it shouldnt make that much differance,so may be you have some other issue.
  6. Re: stupid question about turbo's
    yes ok sorry,
    i have just had a new turbo fitted after a disaster that could have been a lot worse, had a new oil pump fitted then turbo.
    i have a previous thread where i explained my troubles in more detail
    find it here.. https://www.vwaudiforum.co.uk/forum/s...ad.php?t=18124
  7. Re: stupid question about turbo's
    May 2007
    knee deep in clunge
    14 Post(s)
    O dear another 1.8T oil sludge,did you clean out the rocker cover and the breather pipes as well,if not do it as the carbon build up will soon circulate back to the sump and block the oil pump strainer(repeat failure).If its a passat or a4 there is a modified oil filter which has a larger capacity that address this issue.Any way back to your problem,providing the g31 and airmass havent been contaminated by oil passing the turbine shaft from the old turbo i would have a look for any fault codes that may have stored.
  8. Re: stupid question about turbo's
    everything was cleaned out where do i find fault codes?
  9. Re: stupid question about turbo's
    Oct 2006
    Out of curiosity, is it all 1.8T that suffer from this sludging? And would a more frequent oil change with top spec oil stop or reduce it. Also how does it happen?
    A4 Avant 1.9 TDi160 for when the weather is on the damp side - Sold after 9yrs. Now A5 3.0TDI Q Sport Coupe (310bhp/480ft/lbs - Yamaha R6 for when its dry and want some 'High octane Petrol' fun.
  10. Re: stupid question about turbo's
    well id just like to say i took my Audi out for a nice little drive and its all good!!
    according to the mechanic who fixed my car it is a common problem with sludging and a more frequent oil change would help also 1.8T's and set on a long service setting and use oil that is supposed to last these long intervals between services.. but he recommended a service every 10,000 miles to combat this problem.
  1. Hello, am I being stupid? (TDI)
    By tobyho in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-07-2008, 05:14 PM
  2. Call me stupid...
    By LSDJ in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-10-2007, 02:41 PM
  3. CD stupid question
    By alcot33uk in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-09-2007, 09:04 AM
  4. Central locking, something stupid
    By Sodit in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-05-2007, 02:07 PM
  5. turbo's i need one
    By casper in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 30-04-2007, 10:26 PM
